TephraMod V7
Old May 3, 2010 | 05:05 AM
  #1741
chmodlf's Avatar
Originally Posted by tephra
i thought i already setup either 00/01 or 02/03 with 2byte_airflow?
Yes 2byte airflow is MUT 02-03.
Old May 3, 2010 | 07:56 PM
  #1742
AutoXer's Avatar
Originally Posted by AutoXer
After about an hour of searching and sifting, I have to ask. Can someone explain the MUT table in 94170715?
The 2-byte values locations don't look right.
MUT 00 + 01 = 8450 + 8451
MUT 02 + 03 = 89E2 + 89E3
MUT 04 + 05 = Stock
According to The Official 2-Byte thread, the MUT addresses should be:
2byte load
MUT 00 = 895C
MUT 01 = 895D
2byte RPM
MUT 02 = 893A
MUT 03 = 893B
2byte AirFlow
MUT 04 = 89BA
MUT 05 = 89BB
Yes, I've been reading up on Baro and Temp compensated load. None of those addresses seem to match up with what's in the MUT table(00-03).
Originally Posted by Raceghost
On a side note, 2 byte still works. You can utilize it, if you want to change your MUT addresses, or download the latest rom deffinition from Appauldd like I was suggesting.
OK. Anybody know the barometer and temperature compensated load MUT addresses?
Old May 3, 2010 | 10:32 PM
  #1743
PlanoEvo's Avatar
Is there any known issues with fuel trim logging problems using V7 with evoscan. I tried unsucessfully tonight on different laptops to log fuel trims and neither worked using two different versions of evoscan leading me to believe the problem is in V7.
Old May 3, 2010 | 10:33 PM
  #1744
tephra's Avatar
what version of V7 you using?
fuel trims should be fine, unless one of the custom roms has somehow disabled closed loop...
Old May 3, 2010 | 10:34 PM
  #1745
PlanoEvo's Avatar
I used the 88590715
Old May 3, 2010 | 10:35 PM
  #1746
tephra's Avatar
so not one of the preconfigured SD rom's? just the ROM straight from my zip?
Old May 3, 2010 | 10:39 PM
  #1747
PlanoEvo's Avatar
yes pm Kracka he was manning the laptops and can tell you exactly what was going on
Old May 3, 2010 | 10:40 PM
  #1748
tephra's Avatar
i'll wait until he chimes in
Old May 4, 2010 | 04:43 AM
  #1749
bigric09's Avatar
im assuming you had the rear O2 turned off...
Old May 4, 2010 | 06:54 AM
  #1750
Kracka's Avatar
First off let me just say that I don't have any experience using Tephra V7, I've always been a huge fan of V5.10 so thats what I've stuck with for quite some time. PlanoEvo put V7 on his car and I was merely logging it.
Fuel trims (low, mid, high) were not adjusting and were just staying at the default "zero" of .1008 even though we drove for over an hour trying to get them to adjust. O2 feedback trim was cycling normally and as expected. We tried two different laptops running different versions of EvoScan with the same result.
PlanoEvo - My recommendation is to switch back to V5.10 since it was working perfectly for us last week.
Old May 4, 2010 | 07:45 AM
  #1751
tephra's Avatar
well ive seen fuel trims just stop working sometimes... not sure what the problem is...
maybe just reflash the V7 rom again...
Old May 4, 2010 | 10:21 AM
  #1752
Kracka's Avatar
OK thanks. I'll have him reflash the same ROM back on and if that doesn't work we'll just go back to V5.10 and go from there.
Old May 4, 2010 | 10:57 AM
  #1753
tnt1106's Avatar
if you are using one of phenems / recompile 88590715 rom's it may have the rear O2 delete mod (somehow in addition to Tephra's?) and when I first changed to V7 this did not allow me to log fuel trims. look under the per bit section and disable that mod.
side note: Tephra, any suggestions on why in the 88591715 the gear does not use (or display in evoscan) properly? I get:
logged / used Gear=1 (for 1rst - 2nd)
Then: Gear=2 (for 3rd=5th)
The gear based boost worked 100% correctly in V6.
Thanks!
Old May 4, 2010 | 04:00 PM
  #1754
tephra's Avatar
hrmmm.... the only thing i can think of is the MUT addresses have changed... can you let me know what MUTID your logging and what it points to?
Old May 4, 2010 | 05:53 PM
  #1755
tnt1106's Avatar
Evoscan:
<DataListItem DataLog="Y" Color="" Display="Boost Error" LogReference="BoostError" RequestID="8A" Eval="0.0241*x-3.087" Unit="psi" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-5" GaugeMax="5" ChartMin="-5" ChartMax="5" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
<DataListItem DataLog="Y" Color="" Display="Gear" LogReference="Gear" RequestID="40" Eval="x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="5" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="RPM_SPEED_RATIO_AVERAGE" LogReference="RPM_SPEED_RATIO_AVERAGE" RequestID="42" RequestID2="43" Eval="x/36.37" Unit="rpm/kph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
MUT 40 = 8447
MUT 42 = 8448
MUT 43 = 8449
