TephraMod V7
Old May 11, 2010 | 07:51 PM
  #1786
tephra's Avatar
i'll look at it this arvo... unless something comes up :|
Old May 11, 2010 | 07:52 PM
  #1787
cossie1's Avatar
Sweet, cheers mate
Old May 11, 2010 | 08:09 PM
  #1788
Chris Moore's Avatar
Originally Posted by tephra
well #2 was just a mistake in MY XML.. so it doesn't actually affect the tephramod rom
the correct XML for wgdc activation/deactivation table should be:
Code:
<table name="Wastgate Solenoid Activation RPM" address="1a68">
    <table name="Condition"/>
</table>
Sorry for my XML incompetence, but this is what I have in mine.
<table name="BCS Re/De-Activation RPM" category="Global Boost Control Settings" address="1668" type="2D" level="2" scaling="RPMStatLimit">
<table name="Condition" type="Static Y Axis" elements="4">
<data>Reactivate On</data>
<data>Reactivate Off</data>
<data>Deactivate On</data>
<data>Deactivate Off</data>
</table>
</table>
Old May 11, 2010 | 08:20 PM
  #1789
tephra's Avatar
yeah for 94170015 the address should be 1a68 not 1668
Old May 11, 2010 | 08:21 PM
  #1790
Thank you kind sir!
Old May 11, 2010 | 10:05 PM
  #1791
tephra's Avatar
can someone verify that 90550001 has this for cranking enrichment:
<table name="Cranking Enrichment IPW Adder (Main)" address="3a98">
<table name="Coolant Temperature" address="5102"/>
</table>
Old May 12, 2010 | 07:20 AM
  #1792
Icem@n's Avatar
Sounds like 9055 is in progress making? i just looked at my xml and ROM and not seeing that table. Hope that helps.
Old May 13, 2010 | 09:54 AM
  #1793
cossie1's Avatar
</table>
I don't have it in my xml either
I have sent Mattjin a PM as he may know the answer, but he hasn't been online for around 3 months
Old May 13, 2010 | 10:41 AM
  #1794
VGergo's Avatar
Hello,
Where to copy the EvoScan XML Data text ?
Old May 14, 2010 | 05:44 AM
  #1795
evoscan's Avatar
Silver Sponsor
evoscan xmls are in:
C:\Program Files (x86)\EvoScan\EvoScan v2.7\DataSettings
ecuflash metadata xmls are in
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
remove the (x86) if you are not on 64bit windows yet.
Old May 14, 2010 | 07:30 AM
  #1796
MR Turco's Avatar
So i finally tuned my car on V7. i absolutely love the gear dependent boost control. It is amazing. 1st gear is retarded now. The car does seem down on power, it just wont take timing but i doubt that is a rom thing. I think it is just time for a bigger turbo.
Old May 14, 2010 | 07:33 AM
  #1797
Danieln's Avatar
Hi Mike,
How you set the tables for gear dependent boost control and wgdc?
Old May 14, 2010 | 07:41 AM
  #1798
MR Turco's Avatar
Mind you, only 1-3 are really tuned (boost wise). I did some pulls in 4th just to make sure everything was kosher but don't have a set boost map. I have an autox tomorrow so 1st/2nd are all i was concerned with:
Old May 14, 2010 | 07:44 AM
  #1799
Danieln's Avatar
thanks Mike...
Old May 17, 2010 | 07:19 PM
  #1800
black E's Avatar
do i need to change anything to be able to run the omni power 4 bar map sensor? (v7+mods on maf)
if so , can someone give the necessary info please?
sorry if its been discussed already.
Thanks!
