TephraMod V7
Old May 29, 2016 | 10:57 AM
  #3331
Zakie@TIC's Avatar
Sorted the J2534 error, Initially I got a P0462 Fuel level sensor circuit low input so I went on to the Periphery and disabled some of the Bit settings to 0 which cleared the Fuel level sensor issue but gave me the J2534 error but now I'm back with the fuel level sensor issue again after I corrected what gave me the J2534 error. Any Idea how I could disable the Fuel level input low issue.
Old May 29, 2016 | 11:06 AM
  #3332
Klaiceps's Avatar
Try loading the stock ACD map and see if that does anything.
Old May 29, 2016 | 11:26 AM
  #3333
Zakie@TIC's Avatar
ABS lights now gone and ACD seems fine, its the Fuel level low input CEL thats bugging now
Old Jun 9, 2016 | 07:20 AM
  #3334
STIU2SLO's Avatar
how to download
hey everyone I've been reading as much as possible, theres 200+ pages can't read them all but i still can seem to find a link or anything on where to actually download it to my computer? I've gone to the wikipage read the whole thing nothing actually is downloadable. just wondering if anyone has the link to where i can download it from
Old Jun 9, 2016 | 10:22 AM
  #3335
ronaldo9's Avatar
Check PM.
Old Jun 13, 2016 | 07:15 PM
  #3336
sandman121383's Avatar
does 96533706 (v7 + Live Map + Speed Density) support the JDM map sensor? i could not find any information on this.
i was looking into converting over to this from my 94170715 tephra v7 for live maps but i have the jdm map sensor installed and do not see any MAP Sensor "map test " tables. if anyone has a link or the xml to add i'd appreciate it!
OR can i implement live maps into 94170715?
Old Jun 13, 2016 | 07:34 PM
  #3337
ronaldo9's Avatar
It should the jdm map sensor is 3 bar iirc. I'm using an omni 4 bar. You would just need to update your formula to get to calculate correctly in evoscan.
Old Jun 14, 2016 | 06:21 PM
  #3338
the rom i'm coming from i had to put in all the correct stuff for the map sensor. but in this rom i do not see any map sensor tables.
this link says its ready to go just make changes in evoscan
https://www.evolutionm.net/forums/ec...tephra-v7.html
however this link does not have 9653 xml to add/edit.
https://www.evolutionm.net/forums/ec...tructions.html
i'm sorry if this has been answered, i just want everyone to know i have searched extensively before posting the question.
so apparently it is setup default with JDM sensor and xml is only changed if using another map sensor like GM or OMNI?
Old Jun 14, 2016 | 09:01 PM
  #3339
ronaldo9's Avatar
I hope I'm not confusing you but ya the 9653 Rom is a universal Evo 8 rom and no need to change the xml. The link I posted will show you the xml to add to evoscan. Good luck
https://www.evolutionm.net/forums/ec...hramod-v7.html
Old Jun 16, 2016 | 01:09 AM
  #3340
Raceghost's Avatar
Look under EGR Control, I think. Cancel that. I just looked. It's not in their. Mfred did a write up on the JDM sensor as well, looked there it's not in there. He is still active on the board, hit him up.
Old Jun 16, 2016 | 08:11 AM
  #3341
ok thank you! My 1.3 u cable is coming today. when i get done copying all my maps over i'll do a flash and log the map sensor to verify. i'll also double check my evoscan xml, which i'm pretty sure i added already.
thanks for all the help guys!
Old Jul 2, 2016 | 02:22 AM
  #3342
mines5's Avatar
Can any one confirm if 96531706 SD rom works on JDM evo 7 ?
What other SD rom options do i have for JDM Evo 7 and from where i can download them ?
Thanks
Old Jul 3, 2016 | 03:35 AM
  #3343
Ultraspeed EVO's Avatar
disregard
Old Jul 3, 2016 | 06:31 AM
  #3344
todd6027's Avatar
Thanks
Use 90556701
Old Jul 3, 2016 | 11:09 PM
  #3345
mines5's Avatar
Originally Posted by todd6027
Use 90556701
Thanks.
you have PM todd.
