TephraMod V7
Old Nov 22, 2014 | 09:23 PM
  #3181
woodsyr58's Avatar
xml files
hi ppl
I just made a donation to tephra & sent him an email
how long does it usually take for him to reply and send the files?
Old Nov 23, 2014 | 07:12 AM
  #3182
todd6027's Avatar
Originally Posted by evo_q8
i have tried searching as much as I could and have an expert here on the forums help me too.
The car is currently tuned with MAF and is using ROM ID 88580714 and the car runs great. But we want to go SD.
We tried 3d SD using 88586714 - Dint work. Car doesn't even start.
We tried SD using 88591715 - Same - Didnt work - Car doesn't start.
Is there a solution to this?
If not, can i just wire up the AIT and swap ecu with a USDM ecu and call it a day?
Appreciate the help!
did you change immobiliser and immobiliser hex ???
Old Dec 1, 2014 | 06:01 AM
  #3183
mines5's Avatar
i will be switching to tephra v7 for MAF ,
will i have control over idle and cruise AFRs ? i was unable to get it slightly richer at idle with my stock rom , no matter what i did ecu will adjust to 14.7.
Old Dec 1, 2014 | 06:05 AM
  #3184
Raptord's Avatar
Not any more than with a stock rom. You need to either run in open loop or wire in the wideband to simulate the narrowband output and use a rom patch to change the target.
Old Dec 1, 2014 | 12:10 PM
  #3185
mines5's Avatar
Can you please write down the simplest possible way of going open loop at idle and cruising range?
Old Dec 1, 2014 | 04:45 PM
  #3186
ROB-80E's Avatar
Disable closed loop in the ECU periphery.
Old Dec 4, 2014 | 12:14 AM
  #3187
jameswwt's Avatar
Hi, im helping a friend to get his car started from his newly downloaded 88580714 map.
Have follow the instruction shown above to copy and paste the previous map immobilizer and oxFFA bits but the car just wont start.
Do someone have any idea on this problem?
When reload the old map, the car start.
Old Dec 4, 2014 | 12:34 AM
  #3188
tephra's Avatar
whats the original romid?
Old Dec 4, 2014 | 05:58 PM
  #3189
jameswwt's Avatar
Hi Tephra, here the Rom Id
The previous ecu is from Ecutek
Hope you could help.
Thank you.
Old Dec 4, 2014 | 06:08 PM
  #3190
tephra's Avatar
ok im not sure you can go from 88570008 to 88580014...
you can try disabling the immob entirely, if it still doesn't start then ...
Old Dec 4, 2014 | 08:13 PM
  #3191
jameswwt's Avatar
Hi, tqvm for kind advise and how can we completely deactivate the Immobilizer?
Old Dec 5, 2014 | 04:47 AM
  #3192
mines5's Avatar
I am using a 93660005 rom, i wanit to switch to tephra v7 . What are the important parameters which i need to copy and paste on to the tephra rom inorder to maintain my previous tune ?
The maf scaling ,injector scaling , injector battery voltage latency comp tables differ to mine .
Old Dec 6, 2014 | 05:24 PM
  #3193
jameswwt's Avatar
Hi Tephra, yes the car can finally start up after disabling the immobilizer.
But now the problem is that the mivec Ign map on 88580014 seems haywire but the idle is smooth as butter.
So, we tried upload rom 88580015, the mivec ign map is understandable to us but it just cant idle. We tried messing around on the latency & timing but it just doesnt work. The car is using stock Evo 9 injectors and oem latency.
Tried copy and paste the 0014 latency to 0015 rom, the car managed to idle but its a little rich and the 0014 latency is very much higher than the 0015.
Pls do advise on how and where should we try to get 0015 rom idle.
Thanks
Old Dec 8, 2014 | 07:27 PM
  #3194
10isace's Avatar
Raptord, if you see this, I thought I read awhile ago, like years ago, that you had the definitions for the 8859 for:
  1. Idle Error
  2. Idle Error - A/C On
  3. Idle Stability Timing Control
IDK if I misplaced it or what, but couldn't find it in my XML as of late. Could you or someone post up the XML? Thanks!!!
Old Dec 9, 2014 | 08:30 AM
  #3195
Raptord's Avatar
  1. Idle Error
I'll check tonight if I have them but off the top of my head, I don't think I do.
