TephraMod V7
If anyone else has these tables defined for the 8859 I'd appreciate it, if it exists on the rom:
- Idle Error
- Idle Error - A/C On
- Idle Stability Timing Control
Thanks!!!
I am on ROM 96530706 with Tephra's V7. Its an 05 MR that didnt come with an ICS from the factory. I use the TPS method to change between maps. Now I have the ICS icon on my instrument cluster and I have it set up in tephra to flash the ICS light when on the alternate map. However, it doesn't flash or light up. Do I need to add a bulb to the 05 cluster for this to work? Has anyone with an 05/06, that didn't come with the ICS setup installed, ever get this light to flash when on their alternate map? Any help would be appreciated.
TIA
TIA
I can't say I've tried to use that on a 05/06, but you can tell if it will work or not by checking the wiring.
First off, No ICS = no bulb. So you could always throw a bulb in there and see if it works.
I would be more concerned with the wiring being missing though. Need to at least check the PCM to see if you have a wire on pin 35. No wire, no way for the light to get grounded.
If the wire is there, then you need to see if the power and ground for the light are wired to the cluster or not.
So I just installed a JDM Evo 7 ECU into my GSR Lancer. Does Tephramod work on Evo 7 ECU's? From what I gather after reading the first page, it's for 8 and 9's only.
My ROM ID is 98640014
I'm not too great at understanding the compatabilities between the different ROMs
