TephraMod V7
Old Aug 21, 2015 | 05:30 AM
  #3256
krazykorean84's Avatar
Originally Posted by sandman121383
the "code" boxes with xml to add to evoscan are not displaying correctly in the OP , can this be fixed? or can the info be reposted?
This is an issue with a bunch of old threads missing xml defs. Check this thread out for info and a couple temporary workarounds.
https://www.evolutionm.net/forums/ec...de-tables.html
Old Sep 8, 2015 | 09:42 PM
  #3257
danfalcas's Avatar
Originally Posted by SS346
Donation sent 90550001
Did you got it? Is he still sending it? This is the one that works on Evo 7 93390000 ROM?
Old Sep 10, 2015 | 11:39 PM
  #3258
flesher's Avatar
Please, help me.
where to download xml 96536706 ?
Name firmware EVO7_2.1_8.8CR_3586_TOMEI280X67.
Ecuflash ID F52 addres 4byte 96536706
Old Sep 24, 2015 | 09:01 AM
  #3259
SeanV's Avatar
90550701 Launch Maps Not working
Hi guys, need some help please.
I am busy tuning a JDM Evo 7.
Original ROM ID = 98640014
Car in now flashed with Tephra V7 90050701 and everything work 100% except for the fact that it won't "switch over' to the launch maps.
The best it can do it bounce on the set rev limit as defined in the "Stationary Rev Limiter"
I have enabled launch settings as per the screenshot below but the car doesn't want to switch overt to the launch maps.
Anybody have and ideas what could be wrong.
I have confirmed the clutch switch is working, since it is a JDM model, the car won't start unless the clutch is pressed in all the way to engage the switch.
No issues in getting the car to start o\if the clutch is pressed all the way down.
Old Sep 25, 2015 | 05:51 AM
  #3260
ecktt's Avatar
Okay. I also have a JDM GSR Evo 7 Original ROM ID = 98640016 but it didn't come with the clutch switch (or a rear O2 sensor for that matter) but my launch map works (at least I've messed with it and seen boost gains when stationary). Never needed to press the clutch pedal to start the car either. I'll check my settings when I get back my cable.
Old Sep 25, 2015 | 12:21 PM
  #3261
SeanV's Avatar
Thanks, please let me know.
I tried increasing the Launch Map Speed Threshold to 15 MPH but still nothing.
Interesting that the stationary rev limiter on the 90050701 V7 works fine but not the launch maps.
For kicks I have just tried the 96530706 V7 but the launch maps also don't work nor does the stationary rev limiter.
Old Sep 26, 2015 | 12:47 PM
  #3262
mines5's Avatar
strangely, i have tried the 9653 v7 on a gta 7 ecu, it works fine, launch maps are working, building boost... cant get the timing go lower than -10. experiencing rev hang issue and rich idle which goes over 10 minutes or so.
Old Sep 26, 2015 | 11:32 PM
  #3263
SeanV's Avatar
Please can you send me your V7 XML file.
Only thing I can think of that might be an issue as everything else seems in order.
Old Sep 26, 2015 | 11:38 PM
  #3264
SeanV's Avatar
Actually nm, I found the original email from Tephra with the XML file in.
Old Sep 30, 2015 | 09:39 AM
  #3265
danfalcas's Avatar
How can I add Speed based stat rev limiter without adding all the tephra mod things?
Old Oct 2, 2015 | 01:48 AM
  #3266
ecktt's Avatar
I've not used the original xml actually. Here's the one I use as a reference.
File Type: xml
Old Oct 6, 2015 | 02:09 PM
  #3267
danfalcas's Avatar
Originally Posted by tephra
90550001 and 96260009 - "donation only" - meaning if you paypal me (whatever $$$'s its worth to you) I will send you the zip.. if you want it sent to another email address - put it in the paypal message
Email address?
Old Oct 10, 2015 | 04:00 PM
  #3268
EvilDSM97's Avatar
Downloaded 96530706 for my 2005 USDM EVO, changed the Immobilizer HEX appropriately but my car won't start until switching back to the old stock ROM. Not sure where I went wrong?
Old Oct 10, 2015 | 09:22 PM
  #3269
ronaldo9's Avatar
Make sure you have the appropriate init code, immobilizer, and immobilizer hex.
Old Oct 10, 2015 | 09:38 PM
  #3270
EvilDSM97's Avatar
I did change the immobilizer hex to 0x0058, however did not change the immobilizer and init code. Do I just copy the same init and immobilizer codes that are in my original rom?
