TephraMod V7
Old Nov 14, 2011 | 07:02 PM
  #2506
JDM_MR's Avatar
Originally Posted by 84ace
I might be a bit off here but I don't think so... You need that file as a base for the tephra v7 xml right? It is what you need. I think you confused the situation when you posted "is it comparable" vs is it compatible in that thread I sent you the link to... Do you see what I mean?
I just went and re-read your posts. Do you want the 8857008 xml or Rom?
If you want the Rom I can't see why seeing as you have 80920002 tephra v7, right?
I need both ROM and xml in order to have a fully functioning v7 for my car.
Old Nov 19, 2011 | 10:34 PM
  #2507
marcusE's Avatar
So I recently was tuned with tscompusa for a 93 and e85 alt map using the IC sprayer button to flash between the two.. Well now my Button must be broken because I cannot switch back to e85 anymore..
How can I seperate the alt map into 1 rom instead of having 1 rom flashed for both 93 and e85?
Old Nov 20, 2011 | 09:15 AM
  #2508
Raptord's Avatar
Make a copy of your current rom, and in that copy switch your alternate ignition, fuel, boost, and injector scaling maps with the main map equivalents.
Old Nov 24, 2011 | 10:35 AM
  #2509
marcusE's Avatar
Um okay I'll try it now
Old Nov 24, 2011 | 11:42 PM
  #2510
stunt2's Avatar
there's "Ignition Unknown Map (warm-up ?)" in my 96530706 V7 rom. anyone knows if this table is functional and till what conditions ?
Old Nov 25, 2011 | 11:23 AM
  #2511
HornstarBU's Avatar
I think it's the timing your car runs during warm up. I change mine to match my timing map basically, although diff axis, so you have to cut it a little.
Old Nov 29, 2011 | 10:32 PM
  #2512
CDrinkH2O's Avatar
Manifold Absolute Pressure Averaging
Hey guys - when this should be enabled in 96530706?
What does it do?
Old Nov 29, 2011 | 10:48 PM
  #2513
CDrinkH2O's Avatar
Wink
What does it do?
Found the answers....
Well, all the changelog for Tephra v7 says is "Added MrFred Airflow Calcs for g/s or lb/min ". I searched and found that this post might be your answer: how-to: airflow rate in gm/s or lb/min and mpg
the MAP averaging is for smoothing out the "boost" data if you have a MAP sensor from an EvoX or an omni 4bar....don't worry about that unless you have an aftermarket MAP sensor. It like, adds the 2 values, current and previous, and then divides them by 2 I think, so there are less "spikes".
Old Dec 2, 2011 | 12:55 PM
  #2514
ecktt's Avatar
Anyone know if the "control closed loop AFR with your wideband O2 system" patch was implemented in 90550701 V7 rom?
Old Dec 8, 2011 | 01:16 PM
  #2515
VGergo's Avatar
which periphery bit need to turn of for :
P0462 Fuel Level Sensor Circuit Low Input ?
USDM evo 9 V7 rom
Old Jan 1, 2012 | 02:17 AM
  #2516
Lmodel's Avatar
One of my New Year Resolution for 2012, V7 for 88570008!
Old Jan 1, 2012 | 07:22 AM
  #2517
JDM_MR's Avatar
That will be nice....
Old Jan 1, 2012 | 09:55 AM
  #2518
todd6027's Avatar
Just hope that Tephra made the same new years resolution
Old Jan 2, 2012 | 12:43 PM
  #2519
HyperDisorder's Avatar
In case anyone who wants it missed it, here is the final NLTS fix for 96260709 users with 3-plug ECU's:
<!-- NLTS Edits for 96260709 with 3-plug ECU's -->
<table name="Set to D0D0 for NTLS. Originally D0CB" address="3E314" type="1D" level="1" scaling="Hex16"/>
<table name="Set to C802 for NTLS. Originally C801" address="3E318" type="1D" level="1" scaling="Hex16"/>
<table name="Set to E000 for NTLS. Originally D092" address="3E40E" type="1D" level="1" scaling="Hex16"/>
<table name="Set to 8895 for NTLS. Originally 8950" address="3E65A" type="1D" level="1" scaling="Hex16"/>
Just wire in a clutch switch to pin 88 as well and you're good to go.
Edit: Looks like this will work for 96530706 3 plug ECU users too, and maybe for any Evo 8 V7 rom.
Last edited by HyperDisorder; Jan 4, 2012 at 04:01 PM. Reason: Additional Information
Old Jan 4, 2012 | 01:56 PM
  #2520
BarryC's Avatar
bump for V7 88570008
