TephraMod V7
Old May 3, 2015 | 09:08 AM
  #3211
10isace's Avatar
Originally Posted by Benja
Yes it can be, there is generally issues that arise using non-standard roms, but these can be worked out by flipping peripherys.
Regarding the changes needed to run 8859 on an AUDM:
Which ones if you don't mind? Is it just the fuel sensor and immobilizer? Is there anything else? And is there a way to get the ICS button to work for map switching via the tune?
Thanks!
Old May 3, 2015 | 11:54 AM
  #3212
stiffdogg06's Avatar
Issue Fixed.
Old May 4, 2015 | 02:24 PM
  #3213
Benja's Avatar
No, just use the correct rom.
Old May 6, 2015 | 02:21 PM
  #3214
SS346's Avatar
Donation sent 90550001
Old May 7, 2015 | 08:28 AM
  #3215
10isace's Avatar
Thanks, I will. For SD is it the 88586714? I can't seem to log 1 byte or 2 byte load with the 88586714. Is there another rom that doesn't use DMA/live?
Old May 7, 2015 | 02:09 PM
  #3216
ecktt's Avatar
Originally Posted by 3VOLUTIONIST
So I just installed a JDM Evo 7 ECU into my GSR Lancer. Does Tephramod work on Evo 7 ECU's? From what I gather after reading the first page, it's for 8 and 9's only.
My ROM ID is 98640014
I'm not too great at understanding the compatabilities between the different ROMs
90550701 V7 is an evo 7 Rom
Old May 11, 2015 | 04:58 AM
  #3217
extreme-eg's Avatar
Hi guys
Where can I find a JDM Evo 9 Rom file and associated bits ? On the front page I only see USDM Evo 9 and JDM/EDM/AUDM Evo 8 ROM files and XML packs.
Thanx
Old May 17, 2015 | 06:55 PM
  #3218
pqek666's Avatar
Hi everybody! I have a problem with my recently v7 flashed Evo VIII... I change everything from my oem rom to the v7 map... the car starts perfect and drives normal, little knock counts on 3 or 4 points that I didn't have with the other rom...
I was trying the launch map and it flashed the CEL so there is knock but I have to tune it... after two tries the car get the CEL on and never turn off... checked and it's the p0505... I have cleared it and today I was in 5ft gear about 2500 rpm and went on again... I've checked it and it's p0505 again...
The car do not have any problem at all.. the idle is at 850~900 and with the air stays the same...
What I have to do to get rid of this CEL? Everything is working perfect...
Old May 17, 2015 | 07:30 PM
  #3219
ronaldo9's Avatar
Have you tried resetting your biss screw with evoscan? Log the steps to see if its inline with your stock rom. I had to play with my iscv settings to stop getting the code.
Old May 17, 2015 | 07:39 PM
  #3220
pqek666's Avatar
I haven't touched the biss... I'll compare the logs tomorrow to see if I have to move the biss or the iscv steps...
Thanks...
Old May 21, 2015 | 11:00 PM
  #3221
Mweisel's Avatar
alright i've looked literally everywhere and i do not get this. I own a macbook pro, I have purchased windows 8, the cable, parallels to run this. I cannot figure out how to actually get the xml file where it needs to be, i have a fresh version of ecuflash, and no idea where the metadata folder is or anything. someone pls.
evo ix RS on e85
Old May 21, 2015 | 11:05 PM
  #3222
3VOLUTIONIST's Avatar
evo ix RS on e85
XML's go in (directory where you installed it) OpenECU>ECUFlash>rommedata>Mitsubishi>evo
Old May 22, 2015 | 07:21 AM
  #3223
Mweisel's Avatar
I did that, there's about 25 other XML files in there, do I delete every single thing in there and just paste the 1 XML required?
Old May 22, 2015 | 07:53 AM
  #3224
Don't delete the others. Just paste yours in there with the rest. ECUFlash automatically picks the appropriate XML(s).
Old May 22, 2015 | 03:03 PM
  #3225
Mweisel's Avatar
Going to sound dumb as hell but I threw it into the correct folder, started it.. how do I know I actually did it correctly?
