TephraMod V7
Old Aug 18, 2014 | 10:46 AM
  #3151
kaganader2's Avatar
Registered User
Originally Posted by jrainwater
If you're looking to shut it off during hard pulls so it doesn't drag on the engine wouldn't speed be an adequate way of doing so as well instead of rpm?
That is how it is done on GM ecus. Enable and disable is based upon by mph.
Old Aug 18, 2014 | 04:04 PM
  #3152
URNVS's Avatar
No, 9k RPM in first gear is much more likely to blow the compressor than 2k RPM in 5th :P
Im not worried about engine drag as much as my 9200 RPM redline.
Old Aug 19, 2014 | 09:41 AM
  #3153
jrainwater's Avatar
I gotcha, didn't realise where you were coming from. Did you ever get your answer? Just message Merlin and ask him nicely to send you the info. He got me the PS memory addresses in minutes lol. Super nice guy, he is for sure.
Old Aug 19, 2014 | 05:47 PM
  #3154
Ghostdriver22's Avatar
Just got new laptop with windows 8.1. cannot get the hex set up or the rom/xml's to read from the folders. any help is greatly appreciated
Old Aug 20, 2014 | 04:30 AM
  #3155
windows 8.1
Originally Posted by NL-evo7
Hey Tephra
Your pm inbox is still full, made donation for the 905-V7 rom.
Email adress to send to is in the PayPal donation.
Thank's
Did he get bck to you? I just tried PM'ing him..
Old Aug 20, 2014 | 05:06 PM
  #3156
tephra's Avatar
if you need to contact me, just email.. myforumname @ gmail.com
Old Aug 22, 2014 | 04:06 AM
  #3157
Evo_newb's Avatar
According to the first page of this topic I would use ROM ID: 9653X706 on my Evo8 FQ300 which has ROM ID 93660005 but read some other threads that suggest other ROM IDs even other versions of Tephra's mod.. I'm a bit confused. Anyone willing to shed some light for me please?
I did download 96532706 btw but just to have a look and seems that is a lot different than the original ROM. Copied over whatever looked to be the same(tables/maps etc) but did not flash anything back to the ecu.
Also, car is a JDM SJGFZ model which is supposed to run a 1bar Map sensor correct? Evoscan is stack at -14.5psi so there should be a problem somewhere. I believe the map sensor is the one at the end of the intake but there is no vacuum line on it. What's the original routing for it? I know the last question is not for this thread but has to do with map as well and if it's a short answer it might as well get answered here?
Thanks
Old Aug 23, 2014 | 03:01 AM
  #3158
Evo_newb's Avatar
So many views after posting and nobody has any ideas? Come on people
Old Aug 23, 2014 | 03:20 AM
  #3159
french's Avatar
Originally Posted by Evo_newb
According to the first page of this topic I would use ROM ID: 9653X706 on my Evo8 FQ300 which has ROM ID 93660005 but read some other threads that suggest other ROM IDs even other versions of Tephra's mod.. I'm a bit confused. Anyone willing to shed some light for me please? I did download 96532706 btw but just to have a look and seems that is a lot different than the original ROM. Copied over whatever looked to be the same(tables/maps etc) but did not flash anything back to the ecu. Also, car is a JDM SJGFZ model which is supposed to run a 1bar Map sensor correct? Evoscan is stack at -14.5psi so there should be a problem somewhere. I believe the map sensor is the one at the end of the intake but there is no vacuum line on it. What's the original routing for it? I know the last question is not for this thread but has to do with map as well and if it's a short answer it might as well get answered here? Thanks
I had a similar situation. My jdm viii come with 93660005. I did successfully run the 9653 rom after disabling several CELs. But the rom I found to work best was the 96260009 rom which is by donation only.
Unfortunately this forum is pro dominantly USDM based if but a lot is applicable to our vehicles.
Old Aug 23, 2014 | 04:56 AM
  #3160
french's Avatar
Also i think you have MAP and MAF sensors mixed up. MAP will be on your intake manifold (if its comes from factory), MAF will be right after your air box.
Old Aug 23, 2014 | 07:08 AM
  #3161
Evo_newb's Avatar
Hi french, thanks for the reply Right, i'll have a go with both then after I sort out some other issues first. Donation is not a problem. I realised that the forum is more USDM but reading through it I can see a lot of people with JDM cars.
Thanks for the clarification between MAP/MAF, I know what they are but maybe didn't give a good description. I was talking about the end of the intake manifold. After reading some more threads though I realised that the MAP should be located at the top of the intake manifold, meaning towards the hood, therefore my car does not have one.
Old Aug 23, 2014 | 07:09 AM
  #3162
Evo_newb's Avatar
Any other opinions also welcomed, i'm all ears
Old Sep 2, 2014 | 05:41 AM
  #3163
conroe's Avatar
Hi! I have a 2006 Evo 9 EDM =) there firmware with DMA support for the MAF?
Old Sep 2, 2014 | 09:15 AM
  #3164
todd6027's Avatar
what rom id
Old Sep 2, 2014 | 01:24 PM
  #3165
conroe's Avatar
Originally Posted by todd6027
what rom id
88580714
