TephraMod V7
Old Aug 1, 2014 | 03:06 PM
  #3136
URNVS's Avatar
Does anyone know how to adjust the low & mid fuel trim scaling/crossover points (Hz)? I cant seem to find that table in the Tephra v7 ROM...I have huge cams and idle at 1k RPM, so my car pretty much never sees low fuel trim :P
Old Aug 1, 2014 | 11:38 PM
  #3137
jeffbeagley's Avatar
For 9653
Code:
	<table name="Closed Loop - LT Trim Control Ranges" category="Fuel" address="35e5" type="2D" level="1" scaling="LT Trim Hz">
		<table name="Conditions" type="Static Y Axis" elements="4">
			<data>Low -> Mid</data>
			<data>Mid -> Low</data>
			<data>Mid -> High</data>
			<data>High -> Mid</data>
		</table>
	</table>
Code:
	<scaling name="LT Trim Hz" units="Hz" toexpr="x*6.29" frexpr="x/6.29" format="%.0f" min="0" max="1610" inc="6.29" storagetype="uint8" endian="big"/>
My values are
Code:
75.48
62.9
522.0700000000001
496.91
Old Aug 2, 2014 | 01:16 AM
  #3138
URNVS's Avatar
Thanks, worked like a charm
Old Aug 3, 2014 | 11:06 AM
  #3139
URNVS's Avatar
Is there an option for AC cut out above XX RPM's? If not, can I please request this feature? Its hot here in AZ but I dont necessarily need the AC compressor pumping at 9k RPM
Old Aug 4, 2014 | 08:06 AM
  #3140
todd6027's Avatar
Originally Posted by Evo6fromcur
does any one have a tune for evo6 similar to this?
ceddy rom available on geekmapped.com
Old Aug 4, 2014 | 08:07 AM
  #3141
todd6027's Avatar
its under Fan Control
Old Aug 4, 2014 | 09:41 AM
  #3142
NL-evo7's Avatar
905-V7 rom
Hey Tephra
Your pm inbox is still full, made donation for the 905-V7 rom.
Email adress to send to is in the PayPal donation.
Thank's
Old Aug 4, 2014 | 12:16 PM
  #3143
criptballer's Avatar
just as an FYI, option 3 for evo 9s is wrong. it's not set up for JDM Map, it's set up for 4 bar Omnipower when you download it.
Old Aug 4, 2014 | 03:03 PM
  #3144
URNVS's Avatar
Im still not seeing "fan control" in any of the tables...Im half blind though :P
Could you post a screen shot of the exact location?
Old Aug 4, 2014 | 04:43 PM
  #3145
jrainwater's Avatar
I have an omni 4 bar so it is perfect for me lol.
Old Aug 14, 2014 | 11:29 AM
  #3146
GreeceS13's Avatar
I cannot upload Tephra Mod with ECUFLASH 1.29 ??
I am using vag com cable and as I know the only version of ecuflash that I can use is 1.29, not newer!
Old Aug 15, 2014 | 04:37 AM
  #3147
evoscan's Avatar
Silver Sponsor
vag com cable will never work with EcuFlash and EvoScan with Mitsubishi, you need an OpenPort 1.3U or OpenPort 2.0 cable.
Old Aug 15, 2014 | 06:02 AM
  #3148
todd6027's Avatar
try here
https://www.evolutionm.net/forums/8397808-post8.html
Old Aug 15, 2014 | 09:21 AM
  #3149
URNVS's Avatar
Thanks but I dont think that is it...? To me it looks like the table for adjusting the electric fan speeds based on rate of travel. I need to disable the AC compressor above a specific RPM.
Old Aug 15, 2014 | 05:35 PM
  #3150
jrainwater's Avatar
If you're looking to shut it off during hard pulls so it doesn't drag on the engine wouldn't speed be an adequate way of doing so as well instead of rpm?
