TephraMod V7
Old Jul 11, 2011 | 04:15 PM
  #2386
Boosted Tuning's Avatar
Originally Posted by mt057
The link for basic V7 015 does not seem to be working. Is it just me? Could some one send me a copy or a good link please.
Post or PM me your email addy and Ill send it over. 9417 right?
Old Jul 14, 2011 | 10:07 PM
  #2387
jdm-vr4's Avatar
just a quick question...
how can i disable immobilizer on 88580714 so that i dont have to use the imobilizer code? can't find it in the perifery and when i copy the original code from the stock rom and paste it to v7 rom the numbers change?
Old Jul 14, 2011 | 10:21 PM
  #2388
dparrish's Avatar
I think it's Periphery0 (FAA) bit 02.
Old Jul 14, 2011 | 10:58 PM
  #2389
tscompusa2's Avatar
bit.3
Old Jul 14, 2011 | 11:08 PM
  #2390
jdm-vr4's Avatar
so just change it from 1 to 0?
Old Jul 14, 2011 | 11:09 PM
  #2391
tscompusa2's Avatar
you got it.
Old Jul 14, 2011 | 11:12 PM
  #2392
jdm-vr4's Avatar
sweet, thanks heaps!!
so why would the original numbers change when pasting to v7?
Old Jul 14, 2011 | 11:18 PM
  #2393
tscompusa2's Avatar
you shouldn't have to disable the immobilizer code unless your current flash you're on now has it disabled already.. which pretty much means the code was lost sometime or another and they disabled it so they could start the car.
im sure you know, but the immobilizer code is a big deal. someone can copy your car key and steal your car with it disabled, where as with it enabled they cant.
so the question is, is it disabled on your old rom at that bit? if not then try to copy over your existing code from the old rom to the v7.. dont forget to use 0x before the code.
also dont forget to set the year for the car in immobilizer hex.
no problem.
Old Jul 15, 2011 | 01:49 AM
  #2394
drigo's Avatar
Donation Made Sent Email/PM to Tephra. Have a JDM Evo 8 MR but was unable to check if it was 96260007 or 96260009 base so wondering if it was ok to request corresponding Tephra ROM for Both
Donation was made from deanrigs@gmail.com
Old Jul 15, 2011 | 06:38 AM
  #2395
dparrish's Avatar
I have a JDM 8 MR and use 96530706. It works fine.
I gave 96270709 a go briefly because it was closer to my factory ROM but it didn't improve anything, and the XML wasn't as complete.
Old Jul 15, 2011 | 06:26 PM
  #2396
03Ev0luti0n's Avatar
i have a question about the conversion from 94170008... more so exactly how do i got about doing this... all the posts i'm reading say to convert to 94170015... i did that and when i tried to open the modified BIN file i get an unreadable error code in ECU flash.
Sorry I'm kind of a noob... I've watched the tutorials and was able to upgrade to V4 with no issues but that was on 94170008...do i just download the "stock" 94170715 file on page one... copy the .xml information and paste it over the entire directory file for rom i.d. 94170015.. I assume from there i would just copy my table information from my 94170008 ROM file to the new modified ROM.... which brings me to my next question..... The imobilizer code? Which do i use? The one from my 9417008?
Old Jul 16, 2011 | 10:42 AM
  #2397
getsideways's Avatar
Im having an issue with 1 byte load , Is that what everyone is using With V7,
I always patched in the 2 byte mod and never had issues , im considering just doing that.
My load logs fine, then when i approach max load the load drops straight down into the 10-30 range basicly doesnt log above 300ish.
Anyone else had this issue with 1 byte is there a setting to change in evoscan or something?
Ive never used 1 byte and im searching for the answer on here but havent found it yet.
I just remembered the settings in evoscan that allow for gauge\chart max settings and upped them , i dunno if thats all i needed to do ?
Thanks in advance for the help.
Old Jul 16, 2011 | 12:01 PM
  #2398
And's Avatar
And
you just need to change the scaling value from 1.2 to 1.3 or higher then make sure you also change the scale in evo scan
Old Jul 16, 2011 | 09:05 PM
  #2399
^Thanks for the answer i did find the thread shortly thereafter , It has been so long since i had to mess with this i forgot exactly what to do .
Old Jul 17, 2011 | 08:56 AM
  #2400
nousername's Avatar
Can someone just confirm how I get PSI based boost tables on 96260709 please?
Thanks,
Ant
