TephraMod V7
Old Nov 4, 2009 | 08:12 AM
  #886
donour's Avatar
Originally Posted by baylorar
I'm not disregarding that this works, but I'm more confused as to why this needs to be performed. What in the tephra map is different that causes the problem with idling?
It's not's tephra's modification that requires it. The 96530006 rom almost always idle adjustment.
Sending the SAS command then adjusting the screw is the factory specified way of setting the idle. It's the same for all roms.
d
Old Nov 4, 2009 | 09:47 AM
  #887
fostytou's Avatar
EvoM Community Team
Originally Posted by SWOLN
For EvoScan C:\Program Files\EvoScan\EvoScan v2.6\DataSettings\data is where I have the XML opened to, then I'm lost. Where do I place the XML listed
in the 2nd post? Normally, I'd do it right before the <rom> for Ecuflash ROM editing... Sorry for clogging the thread. Is it after the last bit of code for GPS Altitude ?
Sorry, I thought you were talking about the map tracer.
As posted multiple other times in this thread and others, copy it into the mode2 area, the first area where you see datalog items. This is right near the top, and you can easily identify it by looking at the order of items and matching that order to what you see displayed in evoscan.
https://www.evolutionm.net/forums/ec...ml#post7649192
Old Nov 4, 2009 | 10:22 AM
  #888
mchuang's Avatar
d
Did you have to do that on your car. I just copied over the data from my rom to the V7 rom and it just worked no idle screw adjustment or SAS command needed. Idle was exactly the same as the previous rom.
Old Nov 4, 2009 | 10:36 AM
  #889
baylorar's Avatar
This is what I was expecting. I used the 88590715 rom.
My car idles fine with my current map. I have never touched the BISS screw or used the SAS command previously.
Edit: It's worth noting that I used the 88590715 rom that WASN'T edited by phenem.
Old Nov 4, 2009 | 10:51 AM
  #890
logic's Avatar
donour was referring to 96530006 specifically, as a replacement for whatever version (94170015, 96940011, etc) you might have been running before.
Just switching from 88590015 to 88590715 should have no effect whatsoever. It's basically the same ROM, with some additions. For USDM cars, switching to a 96530006 variant is a significant change in base code.
Old Nov 4, 2009 | 10:58 AM
  #891
mchuang's Avatar
[QUOTE=logic;7683580]donour was referring to 96530006 specifically, as a replacement for whatever version (94170015, 96940011, etc) you might have been running before.
Understood. That was the rom i was referring to also.
Old Nov 4, 2009 | 12:44 PM
  #892
SoCal Rally's Avatar
Any status update on progress on the Evo IX standalone XML files (i.e. all relevant XML definitions in one file, no inheritance from base classes)? Any idea of an ETA?
Thanks!!
Old Nov 4, 2009 | 02:13 PM
  #893
95630706's Avatar
Dumb ?
How do you load color maps?
Under appearance/color maps (in EcuFlash) I can't seem to load maps from my c drive EcuFlash color map files...
TIA
Old Nov 4, 2009 | 04:07 PM
  #894
Evo_Jay's Avatar
So I hate to say this, but is there really no chance for a V7 EVO VIII USDM ROM??
Seems like there still people having problem using this "universal" Rom.
Also, i would just feel better using a USDM ROM on my USDM EVO.
I have already donated towards V7 (even though I dont use it..yet), but Ill be willing to donate more if we can get a EVO VIII USDM V7 ROM.
Old Nov 4, 2009 | 04:09 PM
  #895
tephra's Avatar
ok - given that lots of people are crying for it - I am prepared todo a USDM ROM.
please lets discuss what ROMID everyone is happy with.
Old Nov 4, 2009 | 04:12 PM
  #896
Evo_Jay's Avatar
I say either 94170015 or 96420008.
Maybe 96420008 since it is the newest version from mitsu, being that its a '04 ROM and 94170015 is an '03 ROM.
Also if you use 9417 or 9642, neither of them have the dreaded "throttle hang" that 9653 has (and 9694 for that matter).
Old Nov 4, 2009 | 04:14 PM
  #897
tephra's Avatar
isn't there a 96420011?
NOT 96940011...
Old Nov 4, 2009 | 04:17 PM
  #898
Evo_Jay's Avatar
NOT 96940011...
I believe there is a 96420011, which would be the most current 03-04 ROM.
I did once hear though that 96420011 wasnt a real Mitsu factory ROM, but i think that was just a rumor.
And yes, NOT 96940011. Besides that fact that that ROM itself has a low amount of extra space, it also has the "dreaded throttle hang" since its an 05+ ROM. So a def no on 9694
Old Nov 4, 2009 | 04:20 PM
  #899
tephra's Avatar
agreed on your last point.
ok well I will leave it up to the US guys to discuss and come up with a USiversal ROMID :P
Old Nov 4, 2009 | 04:24 PM
  #900
donour's Avatar
ick.
It seems to me like the better use of time would be to make the 96530006 transition painless.
d
