TephraMod V7
Old Jul 7, 2010 | 10:25 AM
  #1906
travman's Avatar
Originally Posted by EVO8LTW
Bump for help. Basic question: Should I be able to unplug the rear O2 without setting a CEL without doing a resistor mod to the harness plug, if I turn off the heater circuit and run the rear O2 routine in V7?
Thanks!
Yes you can remove the rear O2 if you apply both patches with no CEL...
Old Jul 7, 2010 | 11:12 AM
  #1907
korndogg's Avatar
So when will 94170015 be "fixed"? I'm running 94171715.
Will the "fixes" do anything for lean cold start or anything along those lines?
Old Jul 12, 2010 | 06:32 AM
  #1908
Icem@n's Avatar
Originally Posted by cossie1
I'm ready when you are Dave
Cossie, how the testing for v7 going, progress?
Old Jul 12, 2010 | 07:10 AM
  #1909
talmadgetab's Avatar
I am running the tephramod v7 speed density and I got grams air temp sensor installed and am using this entry evoscan. But my question is how I log kpa. KPA evoscan values that I should choose the log. Btw I'm using omnipower 4 bar map sensor.
Old Jul 12, 2010 | 09:58 AM
  #1910
cossie1's Avatar
Haven't been sent it yet mate, Dave has prob been too busy to finish it off yet.
Old Jul 12, 2010 | 07:36 PM
  #1911
tephra's Avatar
just a quick note about the Load Axis for bigmaps:
both Fuel AND Timing use the same Load that the Fuel maps would normal use (ie Load_Baro_n_Temp_Compensated), please keep this in mind for high-altitude tuners
obviously 1byte load is based off Load_Raw - probably a oversight on my behalf now that I think about it
Old Jul 12, 2010 | 07:50 PM
  #1912
Appauldd's Avatar
Ok Tephra.....tel us the xml we need for the Load Baro Compensated load....so we can have the ability to log it in EvoScan.
Please.
Old Jul 12, 2010 | 07:55 PM
  #1913
tephra's Avatar
Load_Baro_Temp_Compensated is Load_Raw+6bytes...
So not my 1byte loadraw... but the stock one...
Old Jul 12, 2010 | 07:57 PM
  #1914
l2r99gst's Avatar
9653:
2-byte LOAD_Raw (no temp compensation)
8984
8985
2-byte LOAD_Temp_Compensated
8986
8987
2-byte LOAD_Baro_Compensated
8988
8989
2-byte LOAD_Temp_and_Baro_Compensated
898A
898B
Old Jul 13, 2010 | 04:07 PM
  #1915
project_skyline's Avatar
Thanks guy!
Old Jul 13, 2010 | 04:35 PM
  #1916
Appauldd's Avatar
Can we get 8859 and 9417 too please? ? ?
  #1917
Boosted Tuning's Avatar
9417
2byte load RAW = 895C and 895D
2byte load + baro compensated = 8960 and 8961
2byte load + baro and IAT compensated = 8962 and 8963
Old Jul 13, 2010 | 04:36 PM
  #1918
Appauldd's Avatar
Thanks Jay.
Old Jul 13, 2010 | 04:54 PM
  #1919
We have talked about this and this is what you told me.
But I am tuning a car at elevation using 9417 V7 and the timing map and fuel map seems to be following 1 byte or RAW load, when you just said its suppose to follow baro+temp comp'd load, but it doesnt.
Can you double check 9417 and let us know what ROM it uses. I think you may have a small oversight, being that you did 9417 at a totally different time then 9653.
EDIT: Also I have another car, a EDM one, that is running 8858 V7. He is at elevation also but his BIGMAPS seem to be following baro+temp comp'd load like you said it should.
Maybe 9417 is different or you did it different when you made 9417 V7??
Old Jul 13, 2010 | 05:08 PM
  #1920
tephra's Avatar
looks like you are right...
not sure whats going on there...
i can give you a quick patch so that it runs Load_B&T if you like...
