TephraMod V7
Just switched my 94170008 and it works great. Few new idle issues, but it was the defaults on some of the idle and ISCV tables that were not the same. Works mint now.
One question though. I seem to have a slight glitch on the NLTS RPM DROP value. It does not display a value, nor does it let me edit it in any way. Whatever is in there seems to work well as the NLTS works mint. I'm just wondering if theres a fix for it incase I want to tweak it a touch.
For reference
For reference
Close EcuFlash and re-open it.
You should be able to see the value now.
You must type the following EXACTLY....
Click on the hex block
hit =
type 0x0040
enter
save the rom
ok so which do i put where? when opened they both say hex.
As it appears in v7:
immobilizer D921?correct?
immobilizer hex 0040?correct?
You are correct on the settings.
As for the alt maps....as long as they are not enabled then you don't have to worry about them. Leave them stock.
The Alt maps are ideal for if you decide to run race gas. Rather than having to re-flash for the better fuel you simply activate the tuned alt maps.
