TephraMod V7
Old Jan 6, 2010 | 05:26 PM
  #1306
R/TErnie's Avatar
Originally Posted by fostytou
The thing that really stands out to me there is that you don't have a ton of positive WGDC correction, even though you are at wastegate boost levels. Are you sure your boost adder is set properly?
If that is not the case it might be likely that you are using an incorrect scaling to log and or view the ECUFlash tables.
I doubled my open loop WGDC map and I saw no difference in boost. Something is amiss. The positive WGDC Correction is limited to 10.
Is there a reason why my error is in Load and NOT in Psi?
Mr. Fred,
I'll try that tonight. Thanks
Old Jan 7, 2010 | 12:00 AM
  #1307
xtreme5369's Avatar
Hows it going, I have rom 88590013. Can I use tephra 7. I have added the entire xml into my romdata directory as per instructions. I have the new version of ecu flash. Once I launch ecu flash I still dont see any of the new options. If someone can give me a hand I would really apreciate it. Thanks
Old Jan 7, 2010 | 12:02 AM
  #1308
GST Motorsports's Avatar
You need to use the V7 Rom as well
- bryan
Old Jan 7, 2010 | 12:05 AM
  #1309
xtreme5369's Avatar
- bryan
Thanks for the info. I hate to be a pain, but can u point me where to read how to load that rom? If not I will keep reading and see if I can figure this out. Thanks again.
Old Jan 7, 2010 | 12:09 AM
  #1310
xtreme5369's Avatar
Ok i found and downloaded the roms as well. Do i have to just add the rom into my romdata directory or do i have to replace it with the new ones I downloaded. Once again I hate to bug, but I would really like to get this going. Thanks again.
Old Jan 7, 2010 | 12:18 AM
  #1311
Just put the V7 XML in the romdata directory, then open the Tephra V7 ROM for your MY in EcuFlash, then copy over your necessary tables (immob, etc)
- Bryan
Old Jan 7, 2010 | 12:28 AM
  #1312
xtreme5369's Avatar
Ok cool, I think I got. I opened the the file name teph7 ending with a .bin and it gave me all the options. If im not mistaken all I have to do now is copy all of my settings from my existing tune over to this .bin and bam I should be good to go? Once there all copied I should be able to load it to my ecu. Ill give it a show. Thanks a lot bryan for the help.
Old Jan 7, 2010 | 07:32 AM
  #1313
esevo's Avatar
I'm sorry did I miss V7 + SD for 0015? If not when will it be available?
Thanks
Evan Smith
Old Jan 7, 2010 | 08:24 AM
  #1314
donour's Avatar
EDIT: *whoops* I thought you meant 94170015 or something. :-p
Old Jan 7, 2010 | 09:43 AM
  #1315
R/TErnie's Avatar
he's talking about v7 for Evo 9's
Evan, it appears that we don't have an SD version 7 yet. I'm also waiting for it
Old Jan 7, 2010 | 09:51 AM
  #1316
travman's Avatar
just copy the SD table data into your V7 xml from mrfreds SD patch thread and copy in the settings from his pre-patched rom. No need to wait?
if you need help with that pm me, i have every thing setup in my own V7 rom / xml
Old Jan 7, 2010 | 09:53 AM
  #1317
travman's Avatar
Did you change the scaling to psi? also what map sensor do u use?
Old Jan 7, 2010 | 01:02 PM
  #1318
R/TErnie's Avatar
i have not changed it yet... I'll do that tonight. I can do that in the Evoscan data.xml
This car uses the JDM MAP I use the OMNI 4 bar
Old Jan 7, 2010 | 05:59 PM
  #1319
R/TErnie's Avatar
My deutsch connector did not lock on the female terminal. When I went to connect it pushed the terminal back and it didn't connect. Thanks for the help! I messed up
Old Jan 7, 2010 | 11:35 PM
  #1320
nabilsx's Avatar
so the bugs are solved with the EVO8 V7 mod? or is it still a hassle
PEACE
NAB
