TephraMod V7
Old Aug 31, 2010 | 02:22 PM
  #2011
mullen's Avatar
i have probably read this thread a handful of times and still cant figure out how to switch to v7 haha im computer illiterate
Old Aug 31, 2010 | 02:46 PM
  #2012
Raptord's Avatar
What are you having trouble with, specifically? Plenty of people here ready and willing to help, myself included, if it's within my limited knowledge.
Old Aug 31, 2010 | 10:15 PM
  #2013
D-VO's Avatar
This thread may be of use to you: https://www.evolutionm.net/forums/ec...ur-answer.html This might help also: http://evoecu.logic.net/wiki/96530006
Old Sep 1, 2010 | 08:23 AM
  #2014
mullen's Avatar
i have the rom i want to use( probably 94170715 for now until i can find someone to tune my car on sd) but when i open ecuflash i cant find the file
Old Sep 1, 2010 | 02:35 PM
  #2015
gallas's Avatar
Ok my rom is 88590015. i saved the 88590715 into the directory for ecu flash. i went threw every single value and transfered my current tune over to the v7. my problem is when ever i try save the rom it saves it as if it was a normal stock rom without the tephramod v7 drop-down option on the side.. no matter where i save it or what i do it saves it as a normal stock rom. what is going on...
Old Sep 1, 2010 | 04:18 PM
  #2016
mullen's Avatar
how do i get my rom from here(C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo) so i can load it in ecuflash? i need to convert it to a .bin file if im not mistaken... everytime i try to load it, it says there is no items match your search
Old Sep 1, 2010 | 06:05 PM
  #2017
Raptord's Avatar
Gallas: When you download tephra you get 2 files. "TephraMOD-88590715-v7.xml" is what you put in the "EcuFlash\rommetadata\mitsubishi\evo" directory. Then you open the other file that comes with Tephra, "88590715-TephraMod.bin" and copy your maps into that rom (rename it so you keep the original Tephra rom, just in case). Then you flash that .bin onto your car.
Mullen: You don't convert your old rom (probably a .hex) into a .bin for Tephra. Like I said above for Gallas, you need to take the .bin that comes in the zip when you download Tephra and copy your maps into that, then flash that .bin onto your car. The xml that also comes in the zip goes into the directory that you said, that allows Ecuflash to recognize the new tables in Tephra.
That should get both of you on the right track, but if you're not sure, let me know and I'll explain in more detail.
Old Sep 1, 2010 | 07:19 PM
  #2018
gallas's Avatar
nope same problem. it will save and stay the V7 mod when i change just the immobilizer. but if i save it after i spent awhile changing it over and re open it. it is back to the regular rom format without the V7 additions.. ever single time. ive converted my damn rom at least 6 times, just for it to disappear and lose all my work. no errors when saving. what the hell. its the V7 while im moving things over just cant save. and i have tried saving as, and also just saving over the original file.
Old Sep 1, 2010 | 07:41 PM
  #2019
Raptord's Avatar
Hmm, that's weird. Might need somebody with more knowledge than me to step in on this one.
Old Sep 1, 2010 | 07:46 PM
  #2020
gallas's Avatar
yeah... grr this is so frustrating. i have dont this transfer so many damn times. ive tried to read threw as much as this monster thread as i can and so far i cant even find a single person who has experienced this problem.
Old Sep 1, 2010 | 08:08 PM
  #2021
nothere's Avatar
gallas,
a question, do you remove whatever rom you were using from the xml page, so there is no chance the ecu can pick it up again. At least rename it.
Old Sep 1, 2010 | 08:29 PM
  #2022
gallas's Avatar
Originally Posted by nothere
gallas,
I remove the old TephraMOD-88590715-v7.xml file every time i try re downloading. if thats what your asking. or are you talking about removing my 88590015 file or just re naming that one?
Old Sep 1, 2010 | 08:41 PM
  #2023
nothere's Avatar
try renaming or removing the old 88590015 from the ecuflash xml folder.
Old Sep 1, 2010 | 08:44 PM
  #2024
gallas's Avatar
trying that rite now. so far so good
Old Sep 1, 2010 | 08:50 PM
  #2025
gallas's Avatar
nope as soon as i changed my timing map save and look at it again, its just a normal non moded rom...
