TephraMod V7
Old Sep 1, 2010 | 09:06 PM
  #2026
mullen's Avatar
Originally Posted by Raptord
Gallas: When you download tephra you get 2 files. "TephraMOD-88590715-v7.xml" is what you put in the "EcuFlash\rommetadata\mitsubishi\evo" directory. Then you open the other file that comes with Tephra, "88590715-TephraMod.bin" and copy your maps into that rom (rename it so you keep the original Tephra rom, just in case). Then you flash that .bin onto your car.
Mullen: You don't convert your old rom (probably a .hex) into a .bin for Tephra. Like I said above for Gallas, you need to take the .bin that comes in the zip when you download Tephra and copy your maps into that, then flash that .bin onto your car. The xml that also comes in the zip goes into the directory that you said, that allows Ecuflash to recognize the new tables in Tephra.
That should get both of you on the right track, but if you're not sure, let me know and I'll explain in more detail.
now when you say copy my map, you mean fuel and timing right?
Old Sep 1, 2010 | 09:17 PM
  #2027
mullen's Avatar
its saying that its not supported or is corrupt
Old Sep 2, 2010 | 04:49 AM
  #2028
Raptord's Avatar
Primarily those 2, however any map that is different in your rom from the stock tephra rom should be transferred over. Immobilizer, for example. MIVEC if applicable, if you're running ECU-controlled boost then you'll need to set it up in tephra, but that's a whole other ballgame.
Old Sep 2, 2010 | 11:38 AM
  #2029
Shy's Avatar
Shy
Smile
Hello,
Sorry....this may sound trivial....when can i download the latest version/files for tephra?
is there any summary list of what exactly i need to do to get it working on my ROM ?
Thanks
Old Sep 2, 2010 | 11:49 AM
  #2030
Raptord's Avatar
When? Whenever you want
If you meant where, the links to download are in the first post of this thread. You'll need to scroll down a bit, as it's a long post.
Old Sep 5, 2010 | 11:53 AM
  #2031
colonelfox's Avatar
Some of the links have said they're being repaired since May. That might be why he can't download them. Anyone know why they were yanked down? I tried to find a reason but this thread is a nightmare to search through.
Old Sep 5, 2010 | 04:16 PM
  #2032
tephra's Avatar
what links?
I have a UPS failure over the weekend but the links should be back up atm..
Old Sep 5, 2010 | 04:29 PM
  #2033
colonelfox's Avatar
USDM 94170015 It's said Currently being fixed, will post ASAP for some time. I was just curious what happened since there's at least 2 cars I tuned running around with that ROM.
Old Sep 5, 2010 | 05:16 PM
  #2034
tephra's Avatar
oh right - yeah I am not sure if Phenem has fixed whatever the problem is - maybe pm him?
Old Sep 21, 2010 | 01:36 PM
  #2035
Mr.Nik's Avatar
after reflasing to tephra mod:
Below i listed the code and freeze frame that i got off my OBD 2 scanner. When i get this code i hit what feels like a really fast fuel cut and im only boosting 10lbs of boost. ive looked for boost leaks and couldnt find any, i got a new wastegate and blow of valve and that didnt change anything either.. does anyone kno what is going on with my car be reviewing these specs? any info would be great thanks. rudy
P0234 Engine overboost Condition
DTC that caused freese frame P0234
Throttle position 52.9%
Engine rpm 4796
Load value 100%
Air flow rate 230.57 gr/sec
coolant temp 179
intake air temp 73
ignition timing 1%
Short term fuel trim 1
0%
Long term fuel rim 1
0%
Short term fuel trim 3
-100.6%
Long term fuel trim 3
-100.6%
Speed 49
Fuel system 1
open 1
fuel system 2
N/A
Old Sep 21, 2010 | 10:14 PM
  #2036
ramievo7's Avatar
guys any news on 90550001 v7 ?????
Old Sep 21, 2010 | 10:26 PM
  #2037
tephra's Avatar
guys if you want 90550001 sooner - send me some money...
i've got a lot of stuff on, and the paid stuff takes priority over the unpaid
Old Sep 21, 2010 | 10:43 PM
  #2038
ecktt's Avatar
How much?
I'll sell my blood if I have too for big maps, launch maps and NLTS!
Old Sep 21, 2010 | 10:45 PM
  #2039
tephra's Avatar
as much as you can afford..
i'm not out to break peoples bank accounts
Old Sep 21, 2010 | 11:00 PM
  #2040
R/TErnie's Avatar
Tephra,
Is the MIVEC control on the 88950015 ROM closed loop control? I assume we set the target map and then the ECU tries to hit the target based on a PID loop. If this is the case, are the proportional, integral, and derivative gains available to change? FURTHER MORE or these gain scheduled versus gear ratio?
Reason that I ask is... when you start making 500-600whp the car pulls soo much faster through the lower gears, I'm not confident that the MIVEC is controlled that well by the ECU. The gains for the PI/PID controller might suit 4th or 5th gear, but certainly not 1st and 2nd.
Lmk your thoughts. Thanks
