TephraMod V7
hey guys probly a stupid question but im getting ready to do e85 and im wanting to run the dual maps but im planning on using the tps to control the map switching now my question is if i man my e85 my alternate map when i switch to that map will it stay in that map even after i shut the car off or will i haft to switch maps everytime i drive the car unless im running 92 oct thanks guys
ROM for European EVO
Hello,
I have an European EVO 8 ( 2004 ) with the ROM id:99270000
The Tephra 96530706 should work for all EVO8.
Can I use tis ROM instead of my old ROM id:99270000 ?
For the imobilizer I put the code of my old ROM in.
For the imobilizer hex I put 004D in.
regards
Heinz
regards
Heinz
Do any of you guys know in detail how to get the AEM 5 bar to work with the SD ROMs? I've searched repeatedly over the last few months to no avail. I know it's been done. I have one wired in as of last night in the hopes that I could fumble my way through it but I'd rather get solid info. I found this link but I don't know that the scalings would be the same as I'm using a V7 SD ROM. Any help would be greatly appreciated.
https://www.evolutionm.net/forums/ec...sdm-8-9-a.html
Hey everyone, I am most likely not doing this correctly but I have a USDM Evo 8 with rom id 94170008. When I pasted the xml data into the corresponding xml file none of the values look correct when I open a rom in ecu flash. EX: Rpms are 10000-75000.
After few disappointments with existing xml file for 88580714 ROM, I've finally decided to do my best to clean the definition file and make it up to include all the neccessary things and features. I am quite satisfied with how it looks now, hope it can be useful to other people.
Specific to this .xml:
1) pressure scalings (bara8, bara16, psia8, psia16) are for 4-bar OmniPower MAP-sensor
2) in direct boost tables scalings in bar are used now, but psi scalings are also included in the rom and you can switch that thing easily
3) added tables for direct boost
4) added table for Rear O2 heater CEL disable
Hope it will be useful for the community.
Download link - http://www.sendspace.com/file/tc026t
Quick note for people using 88590715 and can't see their ISCV tables ("Desired ISCV intial step position with AC on-Neutral" and "Desired ISCV intial step position with AC off-Drive")
Right click the table in Ecuflash and click "edit map...". In the Y axis Engine Temp section, enter "8" in the "Elements" box. Do the same for the other table.
question: u know how u made the mod with the CEL flashing with knock.....well could u make the gauges spin around when the key is turned on? been wanting to ask, thought it would be cool
hello
This is my first post here. I dont know if i need do something before...
Well, i have just installed the tephra V7 rom on my evo 8, all works ok, but my idle is too low and i see a lot of tables for it. I have increase the idle speed, but the car does not increase it.
I'm thinking about increase the ISCV steps, but i see a lot of tables...
Can anyone give me an idea about which tables i must modified?
