TephraMod V7
Old Dec 8, 2010 | 11:02 PM
  #2116
Lmodel's Avatar
Donated for 88570008.
Old Dec 9, 2010 | 08:32 AM
  #2117
ug_orf's Avatar
donated for 9055001
Old Dec 11, 2010 | 09:49 AM
  #2118
darwin_evo's Avatar
I have a problem with the V7 evo 8 rom not being able to get lower than -10* of timing despite changing the values of the variables as describe in another thread by Tephra.
Any thoughts Tephra?
Old Dec 12, 2010 | 04:02 AM
  #2119
Benja's Avatar
Yeah I have the same issue with 90550001 V5.10.
I should be seeing -20* but only pulls -10*.
Old Dec 15, 2010 | 05:14 PM
  #2120
Eisen7's Avatar
Perhaps a noob question sorry, but I assume the alternate maps also gives you alternate boost maps?
Reason I ask is I'm looking at ditching my AVCR and using ECU based boost control with a 3-port solenoid etc. One of the cool features I love about my AVCR is having 2 switchable boost settings - low and high
Could you use alternate maps to simply give you low/high boost settings, but leave the fuel/timing tables the same? Or is there another way to have 2 boost settings via the stock ECU?
Old Dec 15, 2010 | 05:19 PM
  #2121
tscompusa2's Avatar
yes you have an alt wastegate duty cycle table. should have emailed me.
Old Dec 15, 2010 | 05:27 PM
  #2122
Eisen7's Avatar
Cheers Tom. Thought I'd post here in case others had the same query.
So is the alt wastegate duty separate from alt maps? Am just thinking if I go E85 later on, I won't be able to switch maps just to get a different boost setting, so it would be great if you can switch between boost settings independently of the fuel/timing maps. Is that possible in v7?
Old Dec 15, 2010 | 07:46 PM
  #2123
Raptord's Avatar
alt WGDC is part of your alt map.
Old Dec 15, 2010 | 08:14 PM
  #2124
Eisen7's Avatar
OK thanks for confirming. So I can't really use it to simply switch between a high/low boost setting if I'm using alt maps for 2 different fuel types.
It should do the trick for now though, but if I ever get an E85 alt map, then I won't be able to switch maps just to get different WGDC settings, as the timing/fuel etc will be different too.
Perhaps switchable WGDC maps that are independent of fuel/timing maps will be in v8 Tephra's probably considered it already, but maybe it's not possible.
Old Dec 15, 2010 | 08:30 PM
  #2125
tscompusa2's Avatar
there are 2 tables for the wgdc to have different boost profiles.. one for alt map one for regular map.
Old Dec 15, 2010 | 09:06 PM
  #2126
Raptord's Avatar
I believe Tephra has moved on to the X now, and v7 is the last version to be made for pre-X Evos. Don't quote me on that though.
Old Dec 16, 2010 | 01:45 AM
  #2127
raulhp's Avatar
If you want have 2 different boost settings, you can copy your entire Main fuel and Ignition maps to the Alt fuel and ignition maps, and then change the Atl boost setting...
two differents boost settings, same fuel and ignition.
Old Dec 16, 2010 | 03:06 AM
  #2128
VGergo's Avatar
if there will be update V8 or like this a gear dependant 3D tps and rpm base wgdc would be great .
Old Dec 16, 2010 | 07:13 AM
  #2129
Raptord's Avatar
There is already gear dependant RPM-based WGDC control, and there's a TPS vs WGDC correction table.
Old Dec 16, 2010 | 07:32 AM
  #2130
Chameleon@NLM's Avatar
i searched like crazy all night and didnt find any relevant answers so instead of posting a new thread i will ask here since im running the tephra v7 rom on my IX.
Anyone remove all their manifold sensors without issues? I completely removed all of mine since i have an aftermarket throttle body and manifold and there are 2 sensors behind the manifold which are emissions and the 1 connected to the vacuum line for the fuel pressure regulator, seems once i finally removed that one my WOT is a bit leaner, I can either put it back or tune it out.
Just want to find out what magnus manifold users are doing or what are the long term effects of not having the fuel pressure sensor one if any?
ps - I have no other noticeble issues, no cels of any kind and everything is good so far.. im on speed density also.
