TephraMod V7
Old Mar 27, 2013 | 06:34 AM
  #2866
Howulikemyevo's Avatar
Can someone help me????
I have problems with cruising knocks. Sometimes up to 30 knocks. Start knocking from a low rpm 2000-2500 rpm and keep on knocking until i let go the gas pedal. My tuner dont understand y. I did everything, put my grimmspeed boost controller on a foam wrap so the knock sensor wont feel it. Also have check in the engine for any vibrating.
Is there anyone have this problems???
Old Mar 27, 2013 | 08:00 AM
  #2867
evo8426's Avatar
It spikes to 30 or there are a bunch of 1,2 and 3's which adds up to 30?
If it is a bunch of small numbers adding up then I would say it is probably real knock. If it just spikes to 30 then you need to check the knock sensor to make sure it is not unscrewing itself or that the downpipe is not rattling against the underbody such as the sway bar and cross member bars.
Old Mar 27, 2013 | 09:25 AM
  #2868
unihappytime's Avatar
90550001 v7
Hi Guys,
I am not sure if you can help, I have sent a donation to the legendary Tephra, and asked to see if he can send me the MAF and SD version of 90550701 V7 rom.
Can anyone contact him to see if he has the donation and see if he can help me?
Old Mar 27, 2013 | 03:32 PM
  #2869
07EvoIX's Avatar
you can check paypal to see if he has accepted the donation.
i know a few people that have donated to tephra and never got a repsonse, myself included.
not happy, but he has taken the money already so not uch i can do anymore.
cheers
Old Mar 28, 2013 | 01:02 AM
  #2870
JD Ashley's Avatar
Ok, well I attempted to do some research on my problem. Possibly I just missed it? Anyway, I recently switched over 96530706 from 96940011, 05 usdm and ever since I switched my car has been throwing the p0505 of doom. I read while searching around that it is one of the tables for my ISCV, but I have no idea which one needs to be corrected. As I said, I could have possibly missed the answer, but if anyone has this knowledge off hand please help lol
Last edited by JD Ashley; Mar 28, 2013 at 01:19 AM. Reason: added what rom I switched to
Old Mar 28, 2013 | 05:56 AM
  #2871
glitch_tt's Avatar
I tried here but no success...The files are there but when I tried to join I was not accepted
Is there anyway else to get these files?
Old Mar 28, 2013 | 06:11 AM
  #2872
todd6027's Avatar
its not v7 sd its v5.10 attached
File Type: xml
Old Mar 28, 2013 | 07:57 AM
  #2873
cheers
Yes donations has gone through, I don't mind the donation part, I mean they guy did post most of the stuff for free. if he don't answers then I'm OK.
But a silly question, can a EVO 8 rom be used on EVO 7?
Happy Easter guys!!
Old Mar 28, 2013 | 08:06 AM
  #2874
It 25-30 just between 2200-3500 rpm. Not 1+3+2 knocks. It knocks to 30 knocks at that low rpm until i let go of the gas. This is call cruising knocks for some forum member. I did check to see if the sensor is lose but its not and the downpipe isnt touching the frame either.
I have read about this problems for awhile but no luck yet.
Please help anyone!!!!!
Old Mar 29, 2013 | 11:29 AM
  #2875
raza21_84's Avatar
Emailed tephra for the v7 90550001. No reply. Been few weeks now. Am not a Mapper but would like to start on my car soon. I haven't donated yet. I will donate once I have recieved a reply.
Old Apr 2, 2013 | 08:47 AM
  #2876
glitch_tt's Avatar
Thanks alot .... Gonna try this out and see how it works
Old Apr 2, 2013 | 09:32 AM
  #2877
03lances's Avatar
This seems to be a common issue more so with base lancers that turbo their car, one way to determine if its phantom knock (which really seems likely) is to run some higher octane gas (110, or mix some av gas in) if you still get the same counts its very likely its false knock. If you dont see any wierd timing fluctuations right before the knock occurs and assuming your fuel is fine then you can tune this out with adjusting the knock sensor multipliers if your tuner is comfortable with that
Old Apr 14, 2013 | 08:31 PM
  #2878
gotpsi?'s Avatar
I've got a problem switching to sd I'm hoping someone can help with. I had v7 before running fine, I installed a omni 4 bar, and a gm iat and moved all my maps over to the sd rom and my car will start for a very short amount of time, then it dies. It does not run long enough for my wide band to pick up so I'm not sure if its lean or rich. And if I give the car any gas it dies right away like I turned the key off, and wont even try to start if I have my foot on the gas at all. can some one help me get it running?
Old Apr 15, 2013 | 10:56 PM
  #2879
JD Ashley's Avatar
Anyone have any ideas?
Old Apr 22, 2013 | 07:18 PM
  #2880
glitch_tt's Avatar
I have a question guys....
I am using the 90550001 v7 map (stilll on MAF) the car is doing 478awhp and 473awhp @28 psi on 93 octane. The car is hitting 402 load.
My question is
Is there any way to re-scale my load to 450 or more? Currently at 97% on ID1000cc injectors. Planning on upgrading to 2200 ID. The plan is to switch to c16 and up the boost to 35-40 psi.
I know I will maybe max out the airflow. There is no SD maps for version that I am using.
The stock ECU work perfectly and want to continue using it. If someone can create one for me I am willing to pay for their services
Thanks in advance
