TephraMod V7
Old Oct 11, 2010 | 12:02 PM
  #2071
VGergo's Avatar
I found the topic too, but thank you ! I have the jdm 3bar map sensor in the car from the factory . Woud someone please send me his tephra v7 88580714 edm rom with psi based boost control ? :$ I can give an email adress in pm. ofcoruse without your tuned fuel timing boost map thanks a lot.
Old Oct 11, 2010 | 07:22 PM
  #2072
PeteyTurbo@KHC's Avatar
max total upward WG correction vs. tps has some screwed up scaling for 88590715 on the XML provided in the XML pack.. Just a heads up..
Old Oct 11, 2010 | 07:36 PM
  #2073
23r0k001's Avatar
The scaling or the values that they are set to? Would thus cause rich idle? The issue only seen when I apply the 88591715 though it inherits 88590715.
Old Oct 11, 2010 | 07:52 PM
  #2074
Values they are set to..This is what I have for tps axis:
10139.2
25660.8
10139.2
25660.8
Also this car is not reacting well to this rom but I am going to clean out my xml's and try a fresh one.
Flash car> car will not start(cranks)>flash back tune before applying 0-100 tps scaling>then flash tune that prevents car from starting>car fires right up>wait 10 min and start again=car will not start lol....I also believe I had the map sensor scaling set for jdm 3 bar for the target boost table but I doubt it would prevent the car from starting.. Probably something in the xml or wgdc TPS but I will post up what I find to be the problem.
Old Oct 11, 2010 | 08:35 PM
  #2075
23r0k001's Avatar
10139.2
25660.8
10139.2
25660.8
Most appriciated. These setting for Max total upward wgdc correction vs tps are the same for the rom that works(88590715). The issues is seen when I update it to 88591715.
Old Oct 21, 2010 | 06:53 AM
  #2076
phenem's Avatar
I just updated the second post with the correct XML and correct ROM with the appropriate mods and speed density patches. Please delete and re-download and replace what you have (at least the XML so we are all running the same)
Old Oct 21, 2010 | 06:58 AM
  #2077
binky's Avatar
Hey phenem - just an FYI the primary download location for 'Option 4 96530706 (v7 + Mods)' is broken.
-Bink
Old Oct 21, 2010 | 07:08 AM
  #2078
phenem's Avatar
-Bink
Fixed! Thanks Bink, I deleted the file by accident when I was adding the 9417 stuff
Old Oct 21, 2010 | 07:32 AM
  #2079
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Heh Zach I'm happy I motivated you...lol. Thanks for your help I appreciate it big time
Old Oct 21, 2010 | 08:22 AM
  #2080
neilm's Avatar
hi all
is v7 out for rom 90550001 ? or is it coming out ?
as iv a evo7 and would like to use v7
im on v5.1 now and it works fine but would like to have 1 or 2 more mods to play whit
thanks
ps i did not read all 130 odd pages
Old Oct 21, 2010 | 09:12 AM
  #2081
binky's Avatar
-Bink
Old Oct 21, 2010 | 10:08 AM
  #2082
Appauldd's Avatar
Thanks Phenem.....I was out of the loop with this. If I had known you were working on re-writing the XMLs for 9417....I would have surely helped you out.
I am deployed right now and my down time is pretty boring. If you need help with any XML stuff...please let me know. I will gladly assist where I can.
Paul
Old Oct 28, 2010 | 08:53 AM
  #2083
80210's Avatar
I don't see any Valet Rev Limit Flash Time table box, I can set the rpm limit but not the time I need to hold the pedal in or how long CEL flashes for... any ideas (I used the file for evo IX) on first page?
Old Oct 28, 2010 | 09:45 AM
  #2084
Raptord's Avatar
You're looking for "TPS Toggle Time to Activate" and "TPS Toggle CEL Flash Time". They aren't valet-mode specific, they're also used for TPS-based map switching.
Old Oct 30, 2010 | 10:42 AM
  #2085
AlexEvo6's Avatar
Hi all,
First of all, many thanks for this awesome Rom.
I'm running 96530706 on my VI RS2 with VIII ecu very successfully.
I didn't read all the thread, but I look at the latest xml file and I noticed some small errors (I guess).
The values to enable load based boost control mentionned in the xml file are not correct. You should use the value indicated in MrFred thread related to enhanced boost control.
I quote mrfred :
"Variable for boost control: Stock will read 898A. Change it to 8984. The table is in hex format, so you will have to enter it as 0x8984
The "Load Error RAM Address" and "Load Error RAM Address in Load Error Table" will both read: 8866. Change both to 802A (again, you'll need to enter it as 0x....)
WGDC Correction update delay: Use table #1. Table #2 is for when the vehicle speed exceeds the boost limiting speed. Set the value anywhere from 1 to 10. Each unit is approx 0.08 to 0.1 sec.
Change MUT8A will read 8913. Change it to 802B (again enter it as 0x....)
Change MUT8B will read 8D9F. Change it to 8D21 (again enter it as 0x....)"
You'll find attached the xml with the modification.
Plz tell me know if I'm wrong, but this works for me !
I know this is a "small" contribution, but I think it will prevent some people from questionning and loosing time.
File Type: zip
