TephraMod V7
Old Mar 26, 2011 | 07:37 PM
  #2221
nudge120's Avatar
Originally Posted by tephra
I sent the beta for 90550001 to 4 dudes today..
Should have something in a few days if everything is ok
This is awesome news!
Old Mar 27, 2011 | 01:59 AM
  #2222
donner's Avatar
Is 88570008 v7 also coming in the future?
Old Mar 27, 2011 | 04:00 AM
  #2223
tephra's Avatar
i had planned to.
but - getting motivated todo SH2 stuff again took a long time - as the 90550001 guys will attest too
ive got 96260009 ready as well.. tested a little...
Old Mar 27, 2011 | 05:39 AM
  #2224
Benja's Avatar
Good stuff Dave.
Looking forward to the release.
Thanks for not forgetting us.
Old Mar 27, 2011 | 06:18 AM
  #2225
audiofan's Avatar
Originally Posted by burgers22
Also set the immobilizer to the same as you old ROM, if the car has no Mitsubishi fitted immobilizer set this to 0xFFFF. You may need to try the other immobilizer hex codes.
I have the code set tp the same, I have tried all the Hex codes, and nothing, I even tried 0xFFFF and still doesn't turns on
Can anybody tell me what to do to turn on the car?
Thanks
Old Mar 27, 2011 | 08:41 AM
  #2226
evonut270's Avatar
i had planned to.
great news dave. i can get these both tested as well.I did drop you a PM
Old Mar 27, 2011 | 11:45 AM
  #2227
And's Avatar
And
you can turn the immobilezer off in the periphery bits, have you made sure the hex is correct for the market in the same section as the immob you changing, ie JDM, EDM US etc
Andy
Here are some pics:
Oiginal rom (all I have is immobilizer code and Inti)
Tephra (it has immobilzer code, hex code, inti, ecu internal ID)
both original and tephra to see the match
Thanks
Old Mar 27, 2011 | 04:12 PM
  #2228
audiofan's Avatar
Andy
The hex is correct (EDM) but I tried all of them and it didn't work
I'll try periphery bits
Old Mar 27, 2011 | 06:00 PM
  #2229
HsamehH's Avatar
thank you tephra will donate asap. is the timing retard limit set to -20 ? this will help the antilag if so
Old Mar 27, 2011 | 07:34 PM
  #2230
W2J's Avatar
W2J
Wooot, great news bro really looking foward to this.
Old Mar 28, 2011 | 04:15 PM
  #2231
audiofan's Avatar
Andy
periphery worked great! thanks
Old Mar 28, 2011 | 11:33 PM
  #2232
Ian0611's Avatar
Does anybody know what the stock High Oct. EGR Enabled Ignition Advance table should look like, or could you maybe post one for me to look at for 94170715? The table I currently have reads all zeros but I'm kinda doubting that that's what the stock map looks like based on what I've read about the purpose and funtionality of the system. I know that most of you will say to just disable the system because it's pointless but based on some things I've read it sounds like there can be some performance and economic advantages to using the system. Thanks for your input!
Old Apr 1, 2011 | 11:52 AM
  #2233
ug_orf's Avatar
just checked my PMs...and its not me
great news tho
Old Apr 2, 2011 | 08:57 PM
  #2234
jdm-vr4's Avatar
i had planned to.
You got pm and donation for the 96260009.
Old Apr 4, 2011 | 12:08 AM
  #2235
tephra's Avatar
who did you send it as? Trying to find your email addy...
