TephraMod V7
Old Apr 17, 2011 | 02:23 PM
  #2281
ramievo7's Avatar
Originally Posted by Benja
Delete them all and run Burgers XML only.
Did that and all worked good will hit the strip this weekend and test out v7
thanks guys
Old Apr 18, 2011 | 04:26 AM
  #2282
burgers22's Avatar
Originally Posted by ramievo7
well done burgers22 you been always helpfull
just to clear things up shall we use the 3 xml files now?
90550001.xml
90550701.xml
TephraMOD-90550701-v7.xml
what to delet?
thanks again for the great work tephra
I would suggest renaming the TephraMOD-90550701-v7.xml from xml to a txt file, that way you can still use that xml if needed. Please feed back on your track work and how things went.
Old Apr 18, 2011 | 04:28 AM
  #2283
burgers22's Avatar
Originally Posted by tephra
nice work!
Thanks for all your support on this and the other ROMs.
Old Apr 18, 2011 | 06:19 PM
  #2284
ug_orf's Avatar
Tephra i've donated at 2010/12/09, see post #2117 page 142.
havent send email at the time...
ill PM the detail of Paypal and my email
check it please
Old Apr 18, 2011 | 09:13 PM
  #2285
tephra's Avatar
sorted...
Old Apr 19, 2011 | 04:41 PM
  #2286
criptballer's Avatar
I asked this in the please post evoscan/ecuflash questions but i'm not getting a lot of help.
I uploaded the base v7 map into my evo 8 and i'm having issues logging it properly. I did a wot pull and this is what i get
I have double checked that my 2byte to 1byte load factor in ecuflash and the load1byte table in evoscan are the same, which they are 1.2. my baud rate is standard in evoscan. i'm using openport 2.0. i have the newest version of both as well. and it seems like the new version of evoscan has the extra stuff listed under the "add to evoscan xml" section in the first page of this thread too. thanks for the help.
Old Apr 19, 2011 | 05:03 PM
  #2287
Benja's Avatar
Have you got the correct XML in the directory for Evoscan too?
Old Apr 19, 2011 | 05:23 PM
  #2288
maybe that's the problem.... i have 94170008 in my roms folder in evoscan but i'm using 94170715 v7 hex from tephra. damn it. i'll try to find one, if not i'll update this post with my email to see if someone could email it to me. Thanks.
Update: so i went back to the first page and all i see are the roms for ecuflash and xmls for ecuflash as well. nothing on evoscan roms. can someone send me the correct rom i need for evoscan if that will solve the problem? andrade_josue @yahoo.com
Old Apr 20, 2011 | 09:11 PM
  #2289
Guerillah's Avatar
I tried searching to find out more info about the map switching capability using the accelerator pedal but came up empty handed. How is it done? Do you hold the accelerator down for a certain amount of time before you start the car or ??
Old Apr 20, 2011 | 09:24 PM
  #2290
tephra's Avatar
yup basically
ign on, car not running
hold tps for preconfigured amount of time
its a toggle, so same action to enable/disable
CEL will flash slow or fast depending which map your on..
ics light should also flash
Old Apr 20, 2011 | 10:06 PM
  #2291
Guerillah's Avatar
Thanks for the response tephra!
Old Apr 21, 2011 | 12:01 AM
  #2292
Acree's Avatar
From what I've read so far, it seems that 88591715 (Tephra v7 with SD) is already patched to use the Fuel Temperature input for the MAT.
Can someone tell me how to configure the rom so that I'm actually using the Fuel Temperature Sensor as my MAT sensor? I'm thinking it's already setup that way, but would like a confirmation.
-Acree
Old Apr 21, 2011 | 10:57 AM
  #2293
ug_orf's Avatar
check it please
got it!
thanks
Old Apr 21, 2011 | 12:23 PM
  #2294
yup basically
tephra do you have any ideas for my logging issues?
Old Apr 21, 2011 | 03:50 PM
  #2295
ramievo7's Avatar
ok guys 90550701 does great i went to strip tonight and did 11.1 @ 130 60" was
bad 1.8 i had wheel spin and hob i dont know what the car can does if i run 1.6 !?!
launch maps helped a lot
videos coming soon
