TephraMod V7
I'm seeing this same issue; I did a fresh EvoScan install and only added the definitions in the second post (MAT as well) and get the error. I'll see if I can troubleshoot it down to which XML addition is causing the error.
That reminds me; I should check to see if Maptracer works w/ the BigMaps.
That's pretty damn sweet though! What I'm still trying to figure out is: What is the difference between changing the settings on the MAF compensation table compared to changing it on the MAF scaling table? It looks like they're the same except for the part of the formula you edited. I would think that if they are in fact the same then both tables would change when one value is edited, but it doesn't.
Thanks for the reply fostytou. The next question is: When launching my test car using the launch map with the psi ecu based boost control, I've noticed first gear only holds 12 psi; the boost is normal in first gear without a launch. Also, 5th gear is only holding 12 psi.
I've got the "RPM/Speed to gear" set up using the settings found on MRFred's thread, though I don't think I need it since its not in blue. Any idea what I might be missing?
*EDIT* BTW, is anyone else having issues logging 1-byte load? I'm getting errors that showing load in the 20's when I'm under full boost for about 6 cells.
I've got the "RPM/Speed to gear" set up using the settings found on MRFred's thread, though I don't think I need it since its not in blue. Any idea what I might be missing?*EDIT* BTW, is anyone else having issues logging 1-byte load? I'm getting errors that showing load in the 20's when I'm under full boost for about 6 cells.
Almost the only always readable color map. No idea why they did that.
i'd advise start with a fresh copy and try again, but make sure you're pasting only the correct portions, and in the correct place.Thanks for the reply fostytou. The next question is: When launching my test car using the launch map with the psi ecu based boost control, I've noticed first gear only holds 12 psi; the boost is normal in first gear without a launch. Also, 5th gear is only holding 12 psi.
1st gear might not have enough time/load to build up alot of boost, but it should be higher than that. Make sure your boost adder is set properly also. 5th should have enough time to build that boost so it is possible you are snapping to the settings for 6th. If you have a 5 speed you can set the ratio for 6 to 0.
Are you exceeding the upper limit of your 1 byte multiplier? (255*1.2 = 306 default) If so it will wrap.
fostytou is correct; arrays hold stuff. an index outside of the array means you have more stuff in a place than it should. likely, you have a definition you added at the bottom of the file instead of inside the "mode2" area for mitsu stuff. modding the evoscan files isn't the same as ecuflash files, and can confuse people
i'd advise start with a fresh copy and try again, but make sure you're pasting only the correct portions, and in the correct place.I tried SD v7 rom and I am having a bit of trouble. Manifold Air temperature (connected to fuel temp input, pin 77) logs for some reason as 3A request, not 09 as it supposed to be, and 09 request shows some rubish. 3a request doesnt work correctly. It shows -7 when the temperature is +4, when it is +8 it shows in evoscan 0 degrees celcius. Checked the impendace of the sensor and it correct, so the sensor is working. Checked the voltage coming from ECU and it is 4.7 volts instead of 5. (To figure out what sensor shows temperature I disconnected the plug from MAT sensor and the temperature droped immidiately to -65 degrees)
Guys, can you help me with this ? What have I done wrong ? Anyone having the same problem as me ?
Did you change the MAT bit to pull temps from the IAT sensor AND change the MAT table scale to match the IAT sensor?
I didn't change the bit as it's default to use the fuel temp input which is what my GM IAT sensor is wired to. I'm wondering if all the MAT tables need to be changed or if they are pre-populated w/ the correct information (from your base bin/hex file) to log intake temps. If the table values need to be changed, what are the correct values to populate the tables with (96530006?)
I keep confusing psi and kPa in my logs lol.
