TephraMod V7
Old Mar 20, 2011 | 09:05 PM
  #2206
Ralph's Avatar
Originally Posted by Raptord
This is what your table def. should look like for max upward tps correction:
Thanks! Seems the TPS address was blank :\. I will still guess that this won't fix the not starting problem..
Old Mar 21, 2011 | 04:45 AM
  #2207
Raptord's Avatar
I doubt it will, can't help you with that, sorry.
Old Mar 23, 2011 | 05:06 AM
  #2208
Icem@n's Avatar
Tephra-v7 9055
Hey tephra
Not hearing anything on the progress of the V7 9055. How is that going? It released for testing yet?
Old Mar 25, 2011 | 07:07 AM
  #2209
audiofan's Avatar
Newbie Q's
I'm trying to flash the V7 Tephra:
EDM/JDM/USDM 96530006 (Tested on all years of EDM/JDM/USDM EVO8's)
Option 1 96530706 (v7) Set Immob. HEX to 0x0040 (check to make sure your old ROM was the same)
to my Evolution 8 (which I think is a EDM) came with definition 97470001
The problem is that is doesn't turns on, I think is a immobilizer problem, so:
How do I check the Hex code of the original definition?
I changed the immobilizer code into the Tephra V7 rom, put the same number my definition has, INTI code is the same, I used the Hex it says is for 2005 EDM cars, and nothing
what else can I do? I want to run the Tephra mods on the car
Thanks for your reply
Old Mar 25, 2011 | 07:39 AM
  #2210
HornstarBU's Avatar
Did you save a copy of the original ROM? If so, use the hex that is in it, but in the new ROM. make sure to put "0x" before typing hex in. The car turns, but doesn't start? That's what mine did when I had the immob set wrong.
Old Mar 26, 2011 | 04:49 AM
  #2211
HsamehH's Avatar
no news yet about 90550001 ?
Old Mar 26, 2011 | 06:20 AM
  #2212
audiofan's Avatar
I have the original ROM, where or how do I look for the Hex in it?
I used 0x when typing.
The car cranks but doesn't start, I'm pretty sure is immobilizer
Thanks
Old Mar 26, 2011 | 06:58 AM
  #2213
tephra's Avatar
I sent the beta for 90550001 to 4 dudes today..
Should have something in a few days if everything is ok
Old Mar 26, 2011 | 07:12 AM
  #2214
evo_gerard's Avatar
will donate to that!!!!!!
Old Mar 26, 2011 | 07:16 AM
  #2215
burgers22's Avatar
Thanks tephra! I guess some of the guys in the UK may have it?
Old Mar 26, 2011 | 07:20 AM
  #2216
burgers22's Avatar
Also set the immobilizer to the same as you old ROM, if the car has no Mitsubishi fitted immobilizer set this to 0xFFFF. You may need to try the other immobilizer hex codes.
Old Mar 26, 2011 | 07:24 AM
  #2217
tephra's Avatar
if you want to help beta - drop me an email and I can shoot it through to you
Old Mar 26, 2011 | 07:30 AM
  #2218
philr8's Avatar
Tephra
I just pmd you regarding testing 90550001, I have a car here now i can test for you
Phil
Old Mar 26, 2011 | 07:31 AM
  #2219
tephra's Avatar
yeh i replied!
Old Mar 26, 2011 | 07:32 AM
  #2220
philr8's Avatar
yeh i replied!
Got it, thanks Dave
Will let you know of any bugs asap
