TephraMod V7
Old Sep 4, 2013 | 09:56 AM
  #2956
Raptord's Avatar
Originally Posted by Broke4speed
If you're on the stock Lancer ECU, you'll have the clutch switch already IIRC. Your stock ecu can't do boost control however. You'd need an Evo 8 one, since the hardware in yours doesn't cover the boost solenoid part.
He's using Tephra so he'd have to be on an Evo ECU.
Old Sep 4, 2013 | 10:57 AM
  #2957
*02Lancer*'s Avatar
yes im running evo 8 ecu 96530006 option 5. is the boost solenoid needed for tuning? does the ecu use it for anything, other then allowing me to change boost pressures for higher rpms if im getting detonation?
Old Sep 4, 2013 | 11:08 AM
  #2958
Raptord's Avatar
If you don't use the boost solenoid then you'll only be able to run wastegate pressure.
Old Sep 4, 2013 | 11:18 AM
  #2959
Broke4speed's Avatar
No, I mean the physical ecu, not the rom file. If you have an evo 8 computer, then you can run a boost solenoid. If you are using a lancer ecu with the evo rom file in it...then no boost solenoid is possible.
Old Sep 5, 2013 | 03:48 AM
  #2960
RaceSolutions's Avatar
Originally Posted by mprizolakis
Good day
This is a very hellpfull answer.
But...
I have allready done this to my car (turned off the immobilizer) and with the new rom (88590715) still doesnt starts to me (i have european spec evo 9 too ).
Here is what i want
I have placed bigger injectors and i want to get accees to the syncload menu or acceleration enrichment (or so what something like that) in order to correct fuelling during pressing full throtle. with the 88580714 rom that i have installed too when pressing full throtle the car goes heavilly reach and then it corrects it self...i need to get access to that tables that corrects fuelling but i dont know how to do something like that...i saw that 88590715 rom does that but this rom doesnt works to my car...iam a litle bit confused.
Any sugestion tips or tricks will be a major help
Cheers
Hi M8.
Like you,i m almost new to mitsu roms
I ran stock same rom as you,updated to V7, set immo to 0xffff and also need edit 1 bit of ecu pereferie dont remeber exact,but look some post earlier from me or my starting threat
Best regards. Sandro
Old Sep 5, 2013 | 06:27 AM
  #2961
*02Lancer*'s Avatar
O im sorry i missunderstood your question. yes it is an actual evo 8 ecu. And would there be any other sensor's needed?
Old Sep 5, 2013 | 09:48 AM
  #2962
tscharf18's Avatar
Sorry for the newb question but I just picked up an Evo and it has a v7 launch map but I'm not sure how to get the launch control to work, can anyone enlighten me on how to engage the launch control feature?
Old Sep 5, 2013 | 05:56 PM
  #2963
211Ratsbud's Avatar
Fwiw I have compiled all the advanced fuel options in a v7 XML for 8858 if you look it's here. No need to switch to 8859!
Old Sep 7, 2013 | 02:02 AM
  #2964
Hi.
Just some more noob question
Running V7, as it comes, are the normal maps being used or directly the big Maps?
I m reading up and down the threat,but dont get it really
Thx for any hints
Best regards.Sandro
Old Sep 7, 2013 | 10:18 AM
  #2965
Raptord's Avatar
Normal maps aren't used in V7. You need to convert them to bigmaps either by hand or by using a conversion tool that can be found on the forum (search bigmaps conversion)
Old Sep 7, 2013 | 10:35 AM
  #2966
Thx for the hint...i have tried the bigmap conversion tool,but my stock maps are bigger than what the conversion tool wanna see....
I will edit them manually....whohooo... will be nice evening
Best regards.Sandro
Old Sep 9, 2013 | 08:46 AM
  #2967
SmurfZilla's Avatar
Hey guys does anyone have an issue with the AC compressor not kicking on at idle but running fine when the car is moving? I can put power directly to the compressor and it kicks on fine. I posted this issue in the general forum and someone had chimed in and said he has been having this issue since flashing Tephra V7. I have been on nothing but so I wouldn't know any different.
I thought there was a way to turn the compressor on or off at idle but I haven't found it unless its a periphery bit not labeled.
Old Sep 9, 2013 | 10:17 AM
  #2968
SmurfZilla's Avatar
Ok so I dug a little deeper and found a setting under the Periphery on ECU Periphery4 (FEA) Bits, Bit 11 shows P1530 A/C1 Switch. Is this what I'm looking for? Currently it shows a value of 1.
Old Sep 9, 2013 | 12:19 PM
  #2969
AWDBus's Avatar
Are you sure your just not a little low on fluid? You have a high/low pressure switch. If the low pressure switch is hit, it will cut off the comp till pressure comes back up (usually at idle). Its usually the first sign of a a/c leak. A a/c pressure gauge or just a can of 134a will let you know. But also dont over fill as that will put you past the high pressure switch.
Disregard if this has already been checked.
Old Sep 9, 2013 | 12:28 PM
  #2970
I'm running tephra7 on a 2002 Lancer A/T ecu...so not necessarily. Tephra SD also works on my 2002 Sonata AT ecu . Hyundai used a Bosch MAF, so the ecu can't process the Hz of a mitsu one.
