TephraMod V7
Old Oct 20, 2009 | 05:29 PM
  #571
ohhgyeahfasho's Avatar
Originally Posted by fostytou
^^^^LOLOLOL good one tephra. Newbs, can't live with them.... can't bust out the flame thrower without them (We've all been there)
Fired right up here too!
88590715
Tested so far:
-AFR and Timing on launch maps (though I was seeing 3* lower, I think it was from knock)
-Alt-map (bigmap) timing and fuel
-standard map timing and fuel (at idle)
-Narrowband sim patch (mrFred) appears to be working correctly (need to drive more first)
I'll update as I test more!
I was also noticing that my timing on the launch map weren't spot on and sometimes were 1-2* lower. I also just assumed it was because of knock, so I just added more fuel.
Old Oct 20, 2009 | 05:59 PM
  #572
tephra's Avatar
thats the include rear02 sim yes? not a patch applied after right?
Old Oct 20, 2009 | 06:55 PM
  #573
rolly1818's Avatar
Registered User
i have a friend testing 9653 on an JDM Evo VIII, i will update and post rom after for all the JDM'ers
Old Oct 20, 2009 | 08:59 PM
  #574
Chris Moore's Avatar
All of a sudden I can't see my alternate boost maps. They are not showing up anymore.
Old Oct 20, 2009 | 09:01 PM
  #575
tephra's Avatar
did u change the xml?
Old Oct 20, 2009 | 09:05 PM
  #576
Ok heres what happened. Maybe this was already covered and Ive been living in another world. I was looking at my old map of tephra5.10. Since I just downloaded ecuflash 1.42 I had to go find my tephra5.10 folder and add in the correct xml. When that is added into the regular 88590015 map it screws up my 88590715 map. Such as not showing my alternate boost tables.
Old Oct 20, 2009 | 09:10 PM
  #577
I have triple checked this too, it will not show up correctly if my tephra5.10 is patched into my 88590015.
Old Oct 20, 2009 | 09:14 PM
  #578
tephra's Avatar
mmm ok.
i thought the last defined item takes precedence..?
Old Oct 20, 2009 | 09:15 PM
  #579
Want me to try anything?
Old Oct 20, 2009 | 09:19 PM
  #580
tephra's Avatar
can u send me your 2 roms, and the rommetadata directory?
ill give it a go here
Old Oct 20, 2009 | 09:30 PM
  #581
Email sent
Old Oct 20, 2009 | 09:52 PM
  #582
SoCalRedLine's Avatar
Woot 8859 tested and working, altmaps, valet, 3d wgdc, stock maps working fine
transfered my maps by hand, looking forward to doing more fine tuning on this
once I get a yob, I'll be sending some donations...lest u just want my 2cents
Old Oct 20, 2009 | 09:57 PM
  #583
tephra's Avatar
Chris - that's a weird one.
I might forward that to Colby for verification if you dont mind?
Old Oct 20, 2009 | 09:58 PM
  #584
nonschlont's Avatar
I was using this for the thermo fan duty (88590015) and it worked fine using the test v.6 rom, but for some reason its not showing up for me w/ the new v.7... Am I missing somethin?
<table name="Thermo Fan Duty" category="Misc" address="4012" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="9">
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<table name="Engine Temp" address="7034" type="Y Axis" elements="12" scaling="Temp"/>
</table>
  #585
No problem. I assume it did it to you too?
