TephraMod V7
Old Dec 18, 2012 | 05:37 PM
  #2776
Gavstar's Avatar
I have donated to tephra paypal account and requested rom 90550001 a few days ago. I know he is very busy so I was wondering if anybody on here could send me the rom and xml files please. I can send the receipt of donation to whoever helps if you want so you don't think I'm trying to get a handout
Thanks I'm keen as to start using it
Old Dec 23, 2012 | 06:50 AM
  #2777
nikos_paps's Avatar
Hello guys. I have some questions because i cant find the answer anywhere and now i'm confused and i need a help!!!
Firtsly, some infos about my car (evo 9 - rom 88840017). My car is reflashed from another tuner and he put tephra v7 to my car.
I start to do some logs and i saw too many knocks and i create some now maps a little more rich with less ignition timing.
So now i have some question.
1)when i read my rom i read a hex file only(or and xml file)?
2)when i read my rom i cant see tephra mods!
3)i want to write back my new hex file. So if i write back my hex file, i will lost my
tephra mods?
4)when i will write my hex file back to my car,i am also writing and the xml file(stock with no tephra) from ecuflash?
5)how i can read my tephra mods with ecuflash or evoscan?(i dont have his tephra
xml file)
6)which program is right to write back my new tune hex file and keep my tephra mods (ecuflash or evoscan)?
Thank you for your time.
And i hope someone to help me because i want to write back my file today!
Old Dec 23, 2012 | 05:22 PM
  #2778
07EvoIX's Avatar
hi, to answer your questions...
1) it will be HEX or BIN depending on the program used and how you select to save it
2) you need the correct XMLs in your ECUFlash evo folder
3) you wont lose the tephra settings, but i wouldnt flash anything back without having the correct XML first as the tephra fuel and ignition maps replace the stock versions. if you are using the stock version XMLs then you will more than likely stuff things up big time
4) no, it is only the hex/bin file that is written
5) you need the correct XMLs as per 2)
6) either program can read and write
cheers
Old Dec 26, 2012 | 04:41 PM
  #2779
Yiyo's Avatar
Need help I already have my car running with 88590715, Im going to do my car SD I download the 88591715 but for some reason the ROM dont open. Anyone can help me with this THX.
Old Dec 26, 2012 | 05:36 PM
  #2780
domyz's Avatar
Add this xml pack to
Ecuflash/rommetadata/mitsubishi/evo/
Old Dec 26, 2012 | 06:05 PM
  #2781
Yiyo's Avatar
88591715 Problem
I did what you said install the files but continue with the same problem. Attached is a pic THX
Old Dec 26, 2012 | 06:25 PM
  #2782
nikos_paps's Avatar
i want to set tephra v7 in my rom 88840017, but i read the only way is to do all the modification in 88580714 tephra-rom and to write this file to my ecu!right?if i do that i will lost my internal id 88840017 with the new one! Does anyone know if i can have v7 with my rom(i need the xml file)!!! I am trying to set an older tephra v5.5 but when i open the ecuflash i have this error message ''Parse error at line 11, column 3 unexpected character''!how i can fix this?
does anyone knows if this version is ok with my rom?
Thanks guys!!!!
Old Dec 26, 2012 | 07:46 PM
  #2783
Yiyo's Avatar
bump
Old Dec 26, 2012 | 07:47 PM
  #2784
Yiyo's Avatar
Anyone???
Old Dec 26, 2012 | 07:53 PM
  #2785
domyz's Avatar
Anyone???
You must have associated the ROM with wrong or no xml when you first opened it. I don't exactly know how to put back the right xml association (should be simple)... but one thing I'm sure is that will work:
1- remove/reinstall ecuflash
2- reinstall XML pack in the folder
3- redownload and reopen the rom
That will work for sure if you do it right.
Old Dec 26, 2012 | 08:05 PM
  #2786
Yiyo's Avatar
Thx for the info I will let you know tomorrow.
Old Dec 27, 2012 | 02:16 PM
  #2787
Yiyo's Avatar
I did all the steps continue with the same problem ?^&*#$ Can anyone provied me a 88591715 so that way I can copy paste all my stuff and convert my car to SD Thanks in advance for all your help.
Old Dec 27, 2012 | 03:08 PM
  #2788
todd6027's Avatar
whats your e mail
Old Dec 27, 2012 | 03:15 PM
  #2789
Yiyo's Avatar
Originally Posted by todd6027
whats your e mail
g.torresortiz@gmail.com
Old Dec 27, 2012 | 03:18 PM
  #2790
Yiyo's Avatar
Please can anyone read your ecu so that way i can try if work for me 88591715 I dont need your fuel and timing maps Thx
