supertech valve seals
Old Jan 16, 2011 | 09:59 AM
sunrichmond's Avatar
hi i bought some super tech valve seals and saw that it came in blue for the intake and the exhaust side..??aren't the exhaust side supposed to be brown colored?bought this from map performance last month
http://www.streettunedmotorsports.co...stem_seals.jpg
http://76.my/Malaysia/supertech-valv...5-FTZone@7.jpg
Old Jan 16, 2011 | 10:10 AM
C6C6CH3vo's Avatar
exhaust are blue. theyre supposed to be more heat tolerant (yeah. right)
dont bother changing these unless the ones in there are leaking for sure. They are a pain to remove with head on and you'll end up scratching the stems and cashing up your nuckles,. You'll contaminate your oil with blood - which is corrosive
Old Jan 16, 2011 | 11:51 AM
ok so i got them both right,i got the head at the machine shop now
Old Jan 16, 2011 | 11:59 AM
Force-Fed Performance's Avatar
Go ahead and change them. they come off simply with vise grips or stem pliers. Should only take you about 10 min to change them out. Use a deep socket of the same size and tap them onto the stem till they seat down
Old Jan 16, 2011 | 12:04 PM
4RETECH's Avatar
Yes, supertech shipped 16 seals now instead of 8 and 8.
It's okay. I asked also when I got a set to install.
Old Jan 16, 2011 | 12:44 PM
Foxmaster's Avatar
Are all valve seals around the same quality? Any brands I should ignore?
Old Jan 16, 2011 | 01:14 PM
HeadGames's Avatar
there is actually only 2 or 3 manufactures in the world for valve stem seals. Even the big 3 get them all from one place. They are all of similar quality and fit. The only thing you must keep in mind is when your purchasing valve seals for a Supertech spring you must buy either their seal for their spring or you can look for LS Honda from anywhere else. Supertech's duel spring has a smaller inner diameter then any other spring on the market and the inner spring will pull and destroy the larger Mitsubishi sized valve seal.
Old Jan 17, 2011 | 08:23 AM
ChrisCarey's Avatar
You should have 8 ending in "e" and 8 ending in "i" to signify exhaust or intake.
Old Jan 17, 2011 | 10:56 AM
4RETECH's Avatar
That's what I thought, but when I read the label out side the box which had the content label I had, it said 16 valve seals. They were all 6.6 Viton seals. I would have thought they should be (8)half Viton and half (8) polyacrylic.
SLVRNBLK
37
Dec 15, 2017 06:30 PM
0to140in9
Oct 20, 2016 08:02 PM
vipevo9
Jun 9, 2016 11:54 AM
Craig King
26
Oct 31, 2012 05:42 AM
njvlllrs
Nov 13, 2010 07:16 PM
