P0011 - cam sensor out of phase 180*???
Old Feb 13, 2011 | 10:08 AM
atxMR's Avatar
P0011 - cam sensor removal and check? Need to rotate 180*???
I'm throwing the P0011 code so I pulled the cover to my cam sensor to see if I could tell if the sensor was installed 180* out. However, now that I have the cover off I am unsure of how to properly pull the sensor. Can somebody who has dealt with this before please give me a step by step on what I need to do here?
I've searched the other threads on this issue and didn't find a clear how-to on properly installing the cam sensors.
Thanks
Last edited by atxMR; Feb 15, 2011 at 07:45 AM. Reason: clarification of issue I'm trying to resolve
Old Feb 13, 2011 | 05:08 PM
whtrice's Avatar
Veteran: Air Force
Tell us some history on your car. Did you just change cams out recently?
P0011 is "A" Camshaft position Timing Over Advanced. I would suspect possibly the cam gear is a tooth off rather then cam is 180* out.
Old Feb 13, 2011 | 07:35 PM
atxMR's Avatar
Check your PM's.
I've read a number of times on this board that this code will pop up when the cam sensor isn't installed correctly. My car had cams installed just before I bought it and when I bought it I knew there was an issue regarding the cam install. To make a long story short...just assume this is a recent cam install done by a shop that won't warranty their work. Until I know how to correctly pull the sensor and check it's orientation I can't eliminate that being a possible reason for the code...right?
Old Feb 15, 2011 | 07:34 AM
atxMR's Avatar
I must have this posted in the wrong section or perhaps my thread title was misleading. I know there are plenty of people here that have done cam installs and know about the fact that the cam sensor can be installed 180* out. Since I didn't do the cam install I'm not familiar with the procedure. I don't want to just go pull the sensor not knowing whether I may need to follow some precautionary step. Anyone???
Old Feb 15, 2011 | 09:04 AM
atxMR's Avatar
FWIW, I have pulled my cam gear cover and my timing marks are aligned properly.
Old Feb 16, 2011 | 06:51 PM
whtrice's Avatar
Veteran: Air Force
If you read through this cam install thread on Evomoto it will explain the cam alignment
to sensor relationship.
http://www.evomoto.com/tech_articles..._article_id=18
Granted this is an Evo 8 install guide but the cam angle sensors line up the same.
Old Feb 16, 2011 | 07:19 PM
JohnBradley's Avatar
P0011 is MIVEC slow to respond. Look for a clogged feed solenoid or low oil pressure. Mitsu will throw a P0365 if its out of range or over advanced normally. 0011 is almost never the over advanced in the "normal" OBD designation.
http://www.obd-codes.com/p0011
Generally system performance
Old Feb 17, 2011 | 05:59 AM
atxMR's Avatar
Thanks. That's what I was looking to for!
Old Feb 17, 2011 | 06:01 AM
atxMR's Avatar
Thanks! This is probably more likely in my case since my car was down for quite a while. Likewise, the PO used the car for racing on the weekends primarily so over-advanced cam may not be out of the question either.
Old Feb 17, 2011 | 04:24 PM
whtrice's Avatar
Veteran: Air Force
Glad Aaron chimed in. He's the man on this kinda stuff. I had ironically thrown a P0011 myself a few weeks ago. It was the result of a poor idling car. Got my car to idle smoother and the code has not returned.
Old Feb 17, 2011 | 05:54 PM
Old Feb 12, 2013 | 04:27 PM
nosup4all's Avatar
What did u do to smooth the idle down I have the same code
Old Oct 15, 2014 | 07:00 PM
thaoski_taicho's Avatar
Anyone found a direct answer to this? Has anyone found that this causes the car to sputter or hit a wall at wot? I'm having the same issue light goes on for a few miles then goes off again. Any help would be appreciated!
PatricksEvilEvo
Jul 17, 2017 11:08 PM
Sheasta
Jun 20, 2016 12:38 PM
sabastian458
43
Nov 2, 2015 01:35 PM
Sheasta
Sep 27, 2015 07:52 PM
CeliOnce
Sep 14, 2015 05:55 PM
