evo 8 with fp black and 93oct & 30psi + comparisons inside
Ok a little update, Got some time to go out and do some tuning this morning which was still pretty warm. But it was a success so far we dropped boost under 30psi and made some decent power as well. On 93oct 28psi I made 454whp 391 ft/lbs.
this ****er spools quick for a non mivec evo with only 2L displacement and a 68mm compressor wheel. i guess the SD is helping with that.
heres a comparison of a 9 gsr overlayed with the 8 here with similar mods
blue line = 9 GSR
note the 9 gsr is in colder weather also though.. but similar spool, but 9 has gobs more torque downlow.
blue line = 9 GSR
Doesn't a GSR have a different gear ratio since it has taller gears than a MR 6 speed? Wouldn't that affect how fast the turbo spools? Either way the spool looks good on this 6 speed. Good Job!
Still seems low. I have a very similar setup in terms of parts except using buschur IC piping and fmic. Was running around 490whp on 27-28psi of boost on 93pump. Then again the engine was on it's way out.
Is the primary difference between these cars the MIVEC? Because the IX GSR is ****ting all over the VIII in this graph.
ive made 524 on 93oct also on a 2L with a fp black on 93oct with hks 272 cams (mild cams). part combination is really important.. but something is holding this car back at upper rpm. the fp black should not be flat lining like it is before 7k here. hell even on stroker and 2.4's it doesnt drop off uptop.
mods in bold represent what the evo 8 doesnt have
Perrin foam filter
FP 84mm intake pipe
Hallman manual boost controller
FP Black (ported)
25 psi wastegate actuator
AMS intercooler piping (upper/lower)
AMS intercooler
Tial QR recirculating blow-off valve (11 psi spring)
WORKS "Max Bore" 65mm throttle body
Buschur ported intake manifold
Magnus intake manifold heat barrier gasket
Kelford 272 cams
ARP head studs
stock head/stock bottom-end
Walbro 255 fuel pump
ID1000cc injectors
Sparktech ignition
Buschur ported exhaust manifold
Buschur SS O2 housing
Perrin downpipe/cat delete/exhaust
Heres the evo 8
ARP Head Studs
GSC S2
Sparktech Non-cdi
Buschur Ported Coated Manifold
ETS 3.5" FMIC
ETS 3" UICP (I think he replaced this for 2.5")
ETS LICP
FIC 1450cc
Turbosmart Raceport BOV
Hallman MBC in Cabin
JM Fab 4" Intake w/HKS Super Mega Flow Filter
Ported FP Black w/25psi WGA
Map rev2 intake manifold
MAP SS o2 Houseing
Injen Super SES 3" DP, 3" Test Pipe
HKS Hi-Power Catback
heres the 9 gsr mods: (made a max of 487 on 93)
Perrin foam filter
FP 84mm intake pipe
FP Black (ported)
AMS intercooler
Kelford 272 cams
ARP head studs
ID1000cc injectors
Sparktech ignition
Heres the evo 8
ARP Head Studs
GSC S2
Sparktech Non-cdi
ETS 3" FMIC
ETS LICP
FIC 1450cc
MAP SS o2 Houseing
Perrin foam filter
FP 84mm intake pipe
FP Black (ported)
AMS intercooler
Kelford 272 cams
ARP head studs
ID1000cc injectors
Sparktech ignition
Heres the evo 8
ARP Head Studs
GSC S2
Sparktech Non-cdi
ETS 3" FMIC
ETS LICP
FIC 1450cc
MAP SS o2 Houseing
Hmm, so outside the throttle body they seem very similar. MIVEC has to make a bigger difference than a lot of people think because the curve on the IX is massively better.
quite possibly yes.. but honestly based on the characteristics of this vehicle i think someone messed with the head.. possibly the valves are to big or something of that nature.. its just falling on its face at upper RPM where that never happens with the fp black normally. according to the previous owner the head was never touched, but who knows.. its just not acting like a normal evo should so i suspect it was and done wrong at that.
but theres a issue with this car.. as you can see it kind of runs out of juice after 6500, which should not happen.
