evo 8 with fp black and 93oct & 30psi + comparisons inside
Old Jul 14, 2011 | 10:28 PM
  #46
Josh@MooreAutomotive's Avatar
Originally Posted by BLK_EvIL
You think that 3" FMIC could be holding him back with the black and all the heat it's making
Its a 3.5 he always forgets but he tunes so many cars its understandable.
Old Jul 15, 2011 | 12:11 PM
  #47
06MREvo's Avatar
So the boost is tapering 2psi or so by redline & this is with the FP 25psi WGA & Pro RX with the stiff spring correct?? I think the graph looks pretty good, nice power for 93 oct. I would keep an eye on that 6 spd Josh, it may not be too happy with you much longer, haha...
Old Jul 15, 2011 | 08:22 PM
  #48
tscompusa2's Avatar
UPDATE.. we found out why the car was down lots of power.. it was boost leak related at the fuel rail.. will post updated graph shortly.. its much higher tho from what i was just told!
Old Jul 15, 2011 | 08:32 PM
  #49
tscompusa2's Avatar
yes 25psi wga and hallman pro rx with ceramic ball and heavy stiff spring you call in to get.
i was just told it made 48X now after they fixed a huge leak at the fuel rail the oring was torn where the lines go into on the side.
Old Jul 15, 2011 | 09:26 PM
  #50
tscompusa2's Avatar
New results after fixing massive leak.. ignore dip uptop need to take a degree away it was fighting timing.. must be flowing way more air now so need to alter that bit of the map again.
we will get this back on the dynojet to confirm new results also.
Old Jul 15, 2011 | 09:37 PM
  #51
jmcmill3's Avatar
Wow nice
Old Jul 15, 2011 | 10:04 PM
  #52
sparky's Avatar
Gee the beast is healthy!
Old Jul 15, 2011 | 10:56 PM
  #53
Yeah its amazing what a boost leak does lol.
Old Jul 15, 2011 | 11:47 PM
  #54
E-Spec@Tach Motor Works's Avatar
Great job.
Old Jul 15, 2011 | 11:51 PM
  #55
tscompusa2's Avatar
Originally Posted by E-Spec@Tach Motor Works
Great job.
you called it as soon as you seen the dyno sheet. we knew something was screwy but you pointed out the actual dyno sheet was showing power loses uptop right away.. from then on i went on a mission to trying to debug this stupid thing.
Old Jul 16, 2011 | 12:00 AM
  #56
I'm a fanatic about that kinda stuff.... Glad you guys worked your way through it!!
Old Jul 16, 2011 | 12:05 AM
  #57
tscompusa2's Avatar
i had told him a few times to sell the car and he was getting furious with me. all along i was trying to motivate his lazy *** to get out and visually go inspector gadget on the damn engine bay.
Old Jul 16, 2011 | 12:08 AM
  #58
LMAO -- I'm gonna steal that line!!
  #59
tscompusa2's Avatar
Old Jul 16, 2011 | 04:14 AM
  #60
metalsaber's Avatar
Glad you found the issue.
