evo 8 with fp black and 93oct & 30psi + comparisons inside
So the boost is tapering 2psi or so by redline & this is with the FP 25psi WGA & Pro RX with the stiff spring correct?? I think the graph looks pretty good, nice power for 93 oct. I would keep an eye on that 6 spd Josh, it may not be too happy with you much longer, haha...
UPDATE.. we found out why the car was down lots of power.. it was boost leak related at the fuel rail.. will post updated graph shortly.. its much higher tho from what i was just told!
i was just told it made 48X now after they fixed a huge leak at the fuel rail the oring was torn where the lines go into on the side.
New results after fixing massive leak.. ignore dip uptop need to take a degree away it was fighting timing.. must be flowing way more air now so need to alter that bit of the map again.
we will get this back on the dynojet to confirm new results also.
I'm a fanatic about that kinda stuff.... Glad you guys worked your way through it!!
all along i was trying to motivate his lazy *** to get out and visually go inspector gadget on the damn engine bay.
