04-06 Ralliart Engine/Drivetrain (no forced induction)
Headers
Old Sep 8, 2011 | 08:25 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by RalliartN
How can any header cause an emissions test fail? Our car comes stock with a header. As far as the exhaust system is concerned, it is only the cat con that affects the various combustion by-product emission levels.
If it's altered in a way that's not approved by the CARB, you fail. Parts owners are required to display and show all CARB EO numbers upon demand to state referees and law enforcement.
The emissions system that met the California Air Resources Board (CARB) standards at the date of manufacture is the only thing approved for street use. The emissions system has to remain in a form that is either equal to or better than the original system as it was developed by Mitsubishi. The vehicle owner doesn't make that judgement call, it's up to the part developer to go through the CARB testing process.
An exemption from Vehicle Code Section 27156 (VC 27156), California's anti-tampering law, is required before any add-on or modified part can be sold in California. Manufacturers interested in obtaining a VC 27156 exemption for an add-on or a modified part should fill-out and submit an application form to the ARB for evaluation. Detailed information on how to do this can be obtained from the document, "Procedures for Exemption of Add-On and Modified Parts," amended June 1, 1990.
http://www.arb.ca.gov/msprog/aftermkt/aftermkt.htm
Aftermarket parts go through a lengthy and intensive testing process (aka bureaucracy) to see how the part alters the emissions of the vehicle. If the emissions of the vehicle are unchanged or even improved, the part gets approved and given a CARB Executive Order number.
Welcome to California!
Old Sep 8, 2011 | 08:44 PM
CrAnSwIcK's Avatar
so it's a money grab, and most people who aren't HKS or AEM or whatever couldn't be bothered with it, cause they can sell their product to the rest of the world...
that's really retarded, cause here in Ontario, Canada (not california) as long as your emissions are below the limit, they couldn't care less what's done to the car, and what parts are used to do it.
what about turbos? you have to get a CARB approved turbo charger, and CARB approved turbo manifold and downpipe...where do they draw the line? is it only exhaust components? or just stuff they can see?
Old Sep 9, 2011 | 12:35 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
All parts are included.
There are CARB legal superchargers, but I don't know if any turbo components are CARB approved.
Old Sep 9, 2011 | 04:35 AM
CrAnSwIcK's Avatar
that's really unfortunate. and i'm sorry to hear that.
Old Sep 9, 2011 | 03:06 PM
22raptor's Avatar
this is turned out to be a really good info pool. See that was my concern that it would fail visual inspection. I guess i could always just swap the stock headers in there.
Old Sep 9, 2011 | 04:56 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Visual is only part of the smog inspection and test.
Your car still has to pass the ecu code and sniffer test. Sniffer test is both at idle and 3,000 rpms.
Old Sep 9, 2011 | 09:02 PM
CrAnSwIcK's Avatar
if that's the case can you leave the stock headers, and get a high flow cat, straight through muffler, and replace the squished pipe with a round one? would THAT be legal?
Old Sep 10, 2011 | 12:14 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
So here's the deal, if the part on your car does not have a CARB EO number, you're screwed.
It's just that simple.
If your car happens to have a high flow cat and a decent tune, you might be able to pass the sniffer. You might also be able to pass the visual if you take your modified car to your local Mom & Pop test only station since they might be lazy or just plain dumb.
The real problem is when Mr. Highway Patrol pulls your monkey **** over and sees something that doesn't look stock or asks you to pop your hood because he believes you maybe running illegal parts.
That's when the real games begin.
So, the majority of law enforcement doesn't know what comes stock on what specific cars, but can usually tell if something isn't OEM. If they aren't sure, they can just cite you for 'modified exhaust' and let the state referee sort it out. At that point, you're no longer allowed to drive your vehicle on the street legally with the exception of either to work or to school. I speak from experience here, I've been cited for modified exhaust and was sent to the ref so I understand the procedure. The CHP officer thought my car was running a stolen motor, when in fact it was the original motor that came with the car. It's not his job to have a catalog of cars, parts and motors in his brain, that's the referee's job. He had never seen the red valve cover that is standard on the B18C motor in the Integra Type-R, so he opted to send me to the ref.
The state referee is well versed in smog systems, aftermarket parts and engine swaps:
A Referee Center is a state-contracted vehicle emissions test facility that provides certain Smog Check services for motorists. A Referee Center is authorized to offer specialized inspection services that are beyond the scope of California's licensed Smog Check stations. Referee Centers are located primarily at California Community Colleges throughout the state.
http://www.smogcheck.ca.gov/80_BARRe...e_Centers.html
These guys are the gatekeepers that stand between you and that updated vehicle registration license tag. Until you clear your car with the ref, the DMV will not issue you new tags and as such, you'll not be able to drive your vehicle. At that point, you run the risk of having your car impounded.
Motorists whose vehicles fail a Smog Check because of missing or modified emission-related parts, must replace those parts. The BAR's Emissions Parts Locator service helps motorists locate difficult to find emissions parts or if the parts cannot be found, a Limited Parts Exemption is issued. When a Limited Parts Exemption is issued, the motorist must take his or her vehicle to a Referee Center for inspection. If it passes all other aspects of the Smog Check inspection, the vehicle will be certified. If the parts are available in time for the next required smog inspection, they must be installed before the vehicle can be certified.
If you're sent to see the referee, it's pretty much a death sentence for your modified car. At that point, you might as well return your car to stock. I've known people to not even bother with trying to run aftermarket parts because of the sheer costs involved with the parts, labor, dyno and then the cost or removing the parts, retuning the car and then going to the ref. The referee knows what's up, so don't expect to roll in there with an FP Red on your car, injectors and play dumb expecting him to send you on your merry way.
Hope this helps.
Old Sep 13, 2011 | 11:18 AM
RalliartN's Avatar
Thank you for the California law clarifications. Man, that really sucks - it's so stupid I'm sure our politicians will eventually enact that stuff. I didn't understand before because we see all the incredible custom machines being created down there so it appears in California anything still goes.
Cranswick: lots going on with me (mostly good), we'll catch up soon - missed Shannonville last weekend due to obligations out of my control but that won't happen again
Spigles
Lancer Engine Management / Tuning Forums
Jan 11, 2016 01:58 PM
Andrei Spelciuc
Dec 11, 2015 11:07 PM
OZRally462
Lancer Engine Tech
20
Aug 9, 2014 12:07 PM
yellowlancer02
Jan 28, 2003 11:24 PM
