RomDiff tool
Old Jan 10, 2012 | 08:25 PM
Raptord's Avatar
Originally Posted by 92LaserRs
Cool tool! I cant get 1.43 to stop crashing to try out its compare function.
1.43 will crash if your xml has any invalid data in it while 1.42 won't. What romid are you trying to open?
Old Jan 10, 2012 | 08:49 PM
92LaserRs's Avatar
96531706, it will load the bin or hex files, but when i go to compare it will crash, also if i scroll down the table listing it will crash. Any way to tell where the issue is in the xml?
Old Jan 10, 2012 | 09:50 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Post
Since Colby probably develops some similar tool, I will attach what I have till now.
Rename RomDiff.bin to RomDiff.zip (damned site upload rules)
Tool assumes you have intalled EcuFlash in default EcuFlash location.
To those who just want XML parsing, use ILSpy, Reflector or other .Net disassembly tool to get a peek at the code.
@ziad: I may send you the code if you need it in your LiveMap
Known bugs: 1.Static Axis is not yet supported,
2.XMLs have to be well formed, exception otherwise
(e.g. I have found a problem in my 88590015
<table name="Target Minimum Idle"address="3d24"> where a space was missing)
Here is a little how to use:
File Type: bin
Old Jan 11, 2012 | 12:59 AM
ziad's Avatar
acamus code will be awesome, email to livemap at mztec dot org
thanks in advance
Old Jan 11, 2012 | 01:52 AM
acamus's Avatar
thanks in advance
sent
evolve_VIII
Feb 24, 2013 01:02 PM
Beebo05
For Sale - Miscellaneous Automotive
Feb 18, 2012 04:59 AM
gillis13
Feb 16, 2012 07:04 PM
ETS Michael
20
Sep 14, 2009 08:39 AM
il2az
17
Jul 13, 2005 11:00 PM
