AEM EMS Get tuning help for your AEM EMS system.
344AWHP on stock turbo
Old Oct 9, 2004 | 08:35 AM
mdzuricky77's Avatar
Originally Posted by Boost Solutions
Matt, how are you?
George
Just peachy
Old Oct 9, 2004 | 08:49 AM
Basic|Evo's Avatar
did you upgrade injectors or pump? nice number
Old Oct 9, 2004 | 09:37 AM
BJai02's Avatar
Originally Posted by bs
Here is the graph of boost and air/fuel. The boost spikes to 23 and tapers to 20 at redline......it just wouldn't hold anything more to redline. The air/fuel is a nice 12:1 with the race fuel.
Congrats! Nice numbers!
So what AFR did you run with 91 octane? And how much ignition timing are you running at full boost?
Old Oct 11, 2004 | 08:32 AM
bs's Avatar
bs
A gentlemen named Tony Szirka from umstuning helped tune the car and Richard from dynocomp assisted as well. For reference I dyno'd 216whp stock at dynocomp so I gained ~125whp with my mods. I'm not sure how dynocomps dyno compares to dyno4mance, but it definitely reads a little high relative to vishnu. The air fuel on the 91 octane map is right at 11:1.
Old Oct 11, 2004 | 08:35 AM
bs's Avatar
bs
I have not upgraded the injectors or pump yet but those are next on the list along with the arp studs. I'm trying to behave myself in the mean time so I don't mess anything up.
Old Oct 12, 2004 | 06:19 AM
BadazzCR's Avatar
what is your injector duty cycle at since you are running the stock ones on the AEM
Old Oct 12, 2004 | 09:20 AM
Boost Solutions's Avatar
Originally Posted by mdzuricky77
It was tuned by Doug himself who is no longer a part of Boost Solutions. He dynoed it in by himself. A spade is a spade so let's give the credit to tuner himself, Doug AKA Badazzcr. Congrats on your numbers. 344awhp on a Dyno Dynamics is bad ****.
Matt
Matt, what date did the car get dynoed at 392whp?
Old Oct 12, 2004 | 07:26 PM
bs's Avatar
bs
IDC on the pump gas tune is showing 85% @ 7000rpm and around 88% @ 7300rpm. I haven't had a chance to log the race gas map, but I suspect the IDC's are similar because I'm running only marginally more boost at redline and have it leaned out to 12:1.
Old Oct 13, 2004 | 08:50 AM
Dyno4mance's Avatar
FWIW Stock evo's dyno on our dyno from 195 - 210...Very good #'s congrats
Old Oct 13, 2004 | 10:08 AM
Ted B's Avatar
As per my calculations, bs' car would give ~322whp on 109 oct and ~285whp on 91 oct on Dyno4mance's dyno.
FWIW, the 392whp numbers quoted on pg. 1 by MSanad are incomparable because Boost Solutions uses a Dynojet, which gives much higher numbers (common knowledge).
Old Oct 13, 2004 | 10:26 AM
NXT VCTM's Avatar
It's "common knowledge" that dyno dynamics dyno can be corrected from 0 - 100%
Old Oct 13, 2004 | 10:29 AM
MSanad's Avatar
Hey Ted,
Actually if you read what i wrote, you'll notice that i never really said that it was dynoed AT BOOST SOLUTIONS .
FWIW It was dynoed in houston i believe. nice try!
Old Oct 13, 2004 | 10:44 AM
Ted B's Avatar
Ahem, dyno numbers between different type dynos vary WIDELY, and are largely incomparable except through statistical comparisons. My car may very well show 392whp on some dynos, but that is meaningless where comparing Dyno Dynamics numbers are concerned.
Old Oct 13, 2004 | 12:18 PM
Ok, but on a dynojet, you cannot manipulate the numbers, you can just choose the STD or SAE options. They show a little bit of difference depending on conditions.
On a Dyno Dynamics, you can actually input the CORRECTION FACTOR manually, like 17%, 20%, 30%, etc... I remeber my dyno sheet was 502whp, and corrected by 17% was 586 or something like that. I wish we can do these adjustments on the dynojet... But I guess they wanted the tuners to stay away from playing with dyno numbers...
George
Old Oct 13, 2004 | 12:29 PM
Ted B's Avatar
True, and such shortfalls must constantly be taken into account and point out to those who aren't yet aware.
One basically has to learn rough equivalents of both DJ and DD numbers to make sense out of these discussions, and that is assuming to some degree that the different DD operators are using the same correction factors.
