AEM EMS Get tuning help for your AEM EMS system.
Anyone not happy with their AEM EMS?
Old Nov 13, 2004 | 09:30 AM
  #31
silverEVO8's Avatar
Originally Posted by IndyPhil
Silver who did your tuning. I am sick of the 0300 errors and am considering having AMS do a AEM on my car. I was wondering if in the colder months could you send data to AMS on the start and they tell you what to change to get start up better.
Dude, you are lucky. The butthole who "tuned" my car is on the run and has disappeared. Apparently with lots of ppls money and stuff. Therefore you are not likely to get victimized by him like I did......
I'm now getting the 0300 errors as well and I don't like it one bit. Still, if the car will start and run reasonably well, I'll put up with it and try to find a solution. The AEM is a great unit for extracting tons of power from an engine but it does it at a price. If you are bothered by a car that does not run smooth like stock, the AEM is not for you. YMMV, but my experience with it was not good because I do not know how to tune a car and I don't have time, tools or inclination to screw around with it. OTOH, most if not all the really fast and powerful EVOs are running the AEM EMS or similar stand alone ems.
Old Nov 17, 2004 | 02:59 PM
  #32
David Buschur's Avatar
Meta,
I am the one who tuned the car, well the second time, the first guy blew you engine The cold start does need worked on when the car is cold to get it right. I probably have enough new information though to fix your car if you just e-mail me the current map you have.
Let me know if you want to do something.
David Buschur
www.buschurracing.com
Old Nov 23, 2004 | 11:34 AM
  #33
Blak94GSX's Avatar
I just wanted to address a few issues discussed in this thread.
-Cold Start
Raise the value in the Warm Up Enrichment Table until there are no more cold start problems. Also, make sure the O2 Feedback Min Coolant Temp is set to 120-140 so the O2 Feedback doesn't kick in too early and lean things out when the motor is still cold. With the Warm Up Enrichment Table set appropriately high, the AFR should be in the low 12s at idle when cold, then lean out from there until it is fully warmed up. Also, use the Coolant Retard Table to stabilize the idle when cold. Try 0 correction from 140F+ and -15 degrees at -40 coolant temp with a straight line from there to 140.
-Tach "sticking"
LS7 ALT is incorrectly turned ON, turn it OFF
-Inconsistency in changing weather conditions
Use O2 Feedback... There are also trims for Barometric pressure and air temp
Old Nov 24, 2004 | 07:32 PM
  #34
TurbotrixRacing's Avatar
Originally Posted by DynoFlash
My tach needle sticks a bit and its not a big deal - it does not effect the ecu operation in any way. Hopefully they will resolve that but its a minor annoyance.
Go into options / configure outputs ..
Pull up LS7
and disable it .. This will get rid of your " sticky tach " problem
mark
turbotrix
Old Nov 28, 2004 | 11:05 AM
  #35
Jason Siebels's Avatar
I would say if you are bothered by a car that doesn't run as smooth as stock, get someone to tune the AEM who knows what they are doing.
Jason.
Old Nov 28, 2004 | 11:22 AM
  #36
metaphysical's Avatar
Registered User
Jason, I think less than 20% of the claimed AEM tuners could accomplish tuning a vehicle the drives like stock.
Old Nov 28, 2004 | 01:10 PM
  #37
groovytang's Avatar
plain and simple, AEM is for people who have high stage cars, and are eager to accept some driveability issues for tuning with this standalone
its not for for people with bpu
Old Nov 28, 2004 | 03:11 PM
  #38
DynoFlash's Avatar
Whats "BPU"?? Thanks
Old Nov 28, 2004 | 03:45 PM
  #39
Luffy's Avatar
Basic Power Upgrades
Old Nov 28, 2004 | 03:53 PM
  #40
groovytang's Avatar
bpu was coined by suprastore.com , just throwing out some terms at youse guys
Old Nov 28, 2004 | 03:55 PM
  #41
Soon2BEVO's Avatar
Taken from Supra terminology..
Old Nov 29, 2004 | 11:17 AM
  #42
Pruven's Avatar
Originally Posted by metaphysical
I just want to get a feeler of who isn't happy with their AEM EMS and the drivability it offers.
JD
I could name a few..
Dan
Old Nov 29, 2004 | 11:25 AM
  #43
Pruven's Avatar
Dan
I'm just trying to lighten things up, but really it takes time to tune in the driveabilty and idle, full throttle is definitly a faster tune. I really wish the AEM would come with a driveability type tune where all you would have to do is scale the injectors a bit and go. Wishful thinking I guess.
Dan
Old Nov 29, 2004 | 03:55 PM
  #44
Evol_VIII's Avatar
I just drove an AEM equipped honda S2000 that has the Vortech kit on it and I thought it was smoth as silk. I drove it in traffic and on the highway and the car ran fine. The best part about it was when we got to the dyno the car put down 257whp and then my buddy went to work on the AEM and the car made 308whp within 4-5 pulls and under an hour. I think "my" Evo will run better with the AEM then it does with the current Dynoflash that is in the car.
Old Nov 29, 2004 | 04:08 PM
  #45
Blak94GSX's Avatar
Should run at least as good as stock, usually better with AEM EMS properly tuned. Especially EVOs that have big cams and crazy intake manifolds with weird throttlebodies and oddball stuff. They work far better with the AEM EMS than they would trying to retain the ECU.
On a bone stock EVO, the AEM EMS drivability isn't totally perfect, although I don't recommend it for bone stock EVOs to begin with. In fact I only recommend it under very specific circumstances or unless the owner is willing to learn how to tune it themself after the initial setup and professional tune.
The primary disadvantage with the EMS is smog compliance. I tune most cars for improved gas mileage, and that usually makes the smog emissions worse, although the car will get 30+ MPG on the freeway.
