AEM EMS Get tuning help for your AEM EMS system.
Speed density vs MAP?
Old Jul 30, 2005 | 12:59 PM
Precision Dyno's Avatar
The biggest issue will be Emmisions..
That is all.
MAP based systems generally are easier to tune. Much ..
They require that you replace your load sensor (MAF) in the EVO's case and add a Manifold Absolute Pressure sensor (MAP) and an Air temp sensor to calculate air density.
One of the biggest differences will be that a Map based setup will allow the ECU to calculate the density and VE of the engine at a given RPM, Boost and Load level.
The MAF based setup will give the computer a relative VE based on the incoming airflow induced by the turbo and the engine.
Which one is better??
It will depend on which side of the fence you are on.
I prefer Map based setups for higher performance applications SOLEY for the reason that I like to tune with more resolution in the upper load areas of the VE curve.
Normally MAF sensors or the like will have resolution for up to a specific amount of air flow and that is it.
This is basically a lamens version and Im sure others have a different point of view.
For the street, depending on the system you are using to tune with, the difference may be felt.
It doesn't matter if the car is for the street or track. MAP or MAF will depend on which EFI system you are running and its capabilities.
they both have their merits.
As far as the restriction point is concerned, There is a minimal value that can be associated with it. But once you are inducing more than the MAF sensor can measure accurately then you will definately see a difference in the upper HP figure.
Just ask the guys over in Japan with the EVO 9.
Once they change just the intake going to the turbo and pressure differential on each end they lean out under initial boost. That will tell you something about how well a MAF based system compensates for airflow...
Old Aug 3, 2005 | 09:00 PM
Bom's Evo's Avatar
whats emissions?
Old Aug 7, 2005 | 07:42 AM
ninjadoc's Avatar
Originally Posted by ninjadoc
Depends on how they test emissions. If they just do a sniff test...lean it out. If they hook up to the OBD2 connector...switch back to MAF for emission testing, then go home and switch back. A pain but that's what I'm gonna do if my car is ever finished!
Emissions testing was interesting. I left the stock ECU in and used an SAFC. The OBD2 testing couldn't talk to the ECU so they used the sniff test. Apparently the equipment Ohio uses doesn't like to talk to EVO ECU's so they divert to sniff testing as soon as they get an error. I wish I had known that before.
Old Sep 6, 2005 | 10:08 PM
TalonRcR's Avatar
Originally Posted by rlazer5000
^^ LOL, I am actually. Does Michigan have emissions testing at all?
No it does not for the motor city
Chris
Old Jun 1, 2009 | 09:24 PM
detroit pistins's Avatar
lets bring this baby back up to life..lol
Old Jun 3, 2009 | 06:12 PM
MOREPSiTEHBETT4's Avatar
https://www.evolutionm.net/forums/ae...ap-vs-maf.html
^^^some answers for you if interested
Originally Posted by Z1 Performance
a properly tuned MAP based system has nothing but benefits vs the MAF on a forced induction car
Tuning wise, yes it's more time consuming setting a car up MAP based, but it is so worth it in terms of boost response, and fuel control, and overall power
Originally Posted by MalibuJack
Well, the MAF has its issues, but I use a blowthrough setup that eliminates two of the complaints most people have about the maf, which is low airflow issues (idle problems) and misreads/disruption of airflow or blowoff valves/whatnot.
A properly tuned speed density system runs great, but the difference is a speed density system is a calculation, a MAF system is an accurate measurement (within reason)
I have been running a blowthrough FORD based MAF for over a year now, good drivability and no major idle issues that can't be resolved with some simple adjustments.
There is only one real downside to using an aftermarket MAF (besides a 90% ignorance of its existance) and that is on some types of hot-wire maf sensors, you can get some condensation on it when its cold, so it takes a bit longer for the wire to warm up and read correctly... THis seems more common on the GM sensor from the complaints I've heard.
I realize the question is of a stock maf verse speed density.. I still think a properly tuned car running MAF will be more drivable, and be more accurate to engine demands.
There's benefits to either setup.. If your already running a standalone, you might have to seriously weigh your options (The first major advantage is you can swap a stock ECU back to a MAF equipped car without any other changes to revert it, assuming your other mods don't get the ECU cranky)
But if your debating AEM vs Stock ECU, well I have a slightly biased opinion so its unfair for me to comment on..
1) Legality (OBD-II)
2) Adjustability and expertise
3) Data logging ability
4) Drivability
You have to rate each of these things and see which is a higher priority to you, Since several products can fit the bill..
I personally don't think a standalone is a great idea for a daily driver, but there's many guys who are running them and driving their cars daily. Also you have to look at your local inspection stations requirements for OBD-II check and whatnot to pass..
Old Dec 27, 2009 | 10:47 AM
oneofakindtrini's Avatar
This is a little off topic, but how the hell do you guys pass emissions with a stand-alone EMS?
Your tuner can handle that for you...
Old Feb 1, 2010 | 07:38 PM
Bugermass's Avatar
One instance where I think a MAF setup shines over SD, is when you have variable cam angle.. For instance, on a K series acura they use SD, so for every 10deg of variable cam angle there is another set of maps both for high and low cam. So being that you have up to 50deg of advance, you have to tune 4 maps (fuel highcam, fuel lowcam, ignition highcam, ignition lowcam) for 0, 10, 20, 30, 40 and 50deg of cam angle.. Thats means to fully tune out that motor, you have to tune 24 MAPS!!!!.. Then you build your cam angle map for high cam and low cam!! Now there are tricks to speed this up, but it still takes quite a bit of time.. With a MAF based system since your metering actual airflow, once you have your MAF curve dialed in properly you can move the cams all around and the fueling generally stays pretty consistant. You may have to play with timing a bit still but its like 1-20th the amount of work..
Which is better?? They both have their pros and cons.
LostInTheWoods
May 24, 2013 12:37 AM
bbyevo8u
14
Aug 28, 2010 04:40 PM
drifterific
Aug 27, 2010 10:59 PM
esevo
Mar 18, 2010 05:02 AM
alloutDSM
14
Nov 3, 2008 02:00 PM
