AEM EMS Get tuning help for your AEM EMS system.
aem ems on stock maf, pnp
Old Aug 31, 2005 | 08:21 PM
awddyno's Avatar
I've been trying to come up with a decent base map for 30-1313 being a true plug and play and not have to change out the maf unless you elect to. So far the car has made a big difference on overall map. At 16psi I was able to push 246torque and 263horse flat at11.5:1 afr.
Tuning is done on a Mustang AWDDYNO, I will share this cal file to people who needs it. (Just make sure you set your ignition timing).
272 in/ex cams, 3" Buschur turbo back.
I will post some dyno sheets soon
Car idles like stock, runs smooth, and I'm not glowing my manifold like the stock ecu did on my base run
Old Sep 6, 2005 | 08:12 PM
pwerks's Avatar
Not too bad there. Just for comparison, we have gotten 310awhp and 293ftlbs with just the EMS, dp, catback and HKS intake. This was acheived at 18.5 psi with air/fuel at 11.7:1 on an AWD Mustang dyno.
Dave
Old Sep 6, 2005 | 08:37 PM
awddyno's Avatar
Very impressive numbers
Old Sep 9, 2005 | 06:42 PM
gsxturbo60's Avatar
Registered User
im in need of help with
a base map can you send me your so i can have a idea where to start.... i have 680cc injector
Old Sep 9, 2005 | 08:08 PM
awddyno's Avatar
sure, but first, do you know how to set the timing and familiar with aem logs?
and how to set your knock control.
Old Sep 13, 2005 | 06:56 AM
gsxturbo60's Avatar
Registered User
i know a little bit
i think i have it set right
Old Sep 13, 2005 | 09:18 PM
awddyno's Avatar
pm me your email, I can find a way to attach the file here.
I can also set the injectors for 680cc and save it as a different file.
Old Sep 16, 2005 | 04:02 PM
fre's Avatar
fre
Setting knock control is easy. Make a full pass on low boost and note the normal engine noise at all the given rpm levels. Next goto the setup sensors menu and pick knock sensor and then adjust the knock calibration table to just above where you see your normal engine noise level. It usually looks like a curve (half a parabola) and then it flattens up top. Mine flattens at 3v but tune according to normal engine noise. Of course after you get a good level for normal engine noise check mark the knock control box and your set. If at any point the engine nosie exceeds what you consider to be normal (knock calibration table), then it will pull timing according to how you set it. I think mine is like 2.5 degrees per volt or something like that.
awddyno
Sep 21, 2011 06:04 AM
awddyno
Aug 21, 2010 11:23 AM
awddyno
May 12, 2010 05:20 PM
awddyno
12
Jun 5, 2006 06:13 PM
awddyno
Feb 28, 2006 02:06 PM
