AEM EMS Get tuning help for your AEM EMS system.
air temp sensor
Old Sep 13, 2005 | 09:18 PM
ctx2000's Avatar
air temp sensor
hai........can anybody answer this question please.
did you suppose to have air temp sensor in oder to install vta bov?
what i have is recirculate.
Old Sep 13, 2005 | 09:25 PM
awddyno's Avatar
do you need an air temp sensor to use a vent-to-atmosphere blow-off-valve?
no.
Old Sep 13, 2005 | 09:33 PM
ctx2000's Avatar
so what that air temp sensor for?
Old Sep 13, 2005 | 09:37 PM
awddyno's Avatar
air temp.
its a feedback sensor the (ECU) uses to adjust for different conditions. if air temp is too high, you can set your parameters to compensate for it.
Old Sep 13, 2005 | 10:00 PM
ctx2000's Avatar
is that gona be fine if you dont have it?
all i got is AEM ems, the thing on top of the stock manifold( i dont know what's the name of it), i use ebc (hks evc v). no air temp sensor.
Old Sep 14, 2005 | 07:51 AM
awddyno's Avatar
If you are running a map sensor then you need the air temp sensor
Old Sep 14, 2005 | 03:21 PM
ninjadoc's Avatar
You utilize it to convert to a speed density setup using a MAP sensor in conjunction with the AIT sensor. You then eliminate the MAF setup.
Originally Posted by awddyno
air temp.
Old Sep 14, 2005 | 06:35 PM
awddyno's Avatar
you just repeated what I said.
or is that to confuse the other guy.
