AEM EMS Get tuning help for your AEM EMS system.
AIT Sensor Wires?
Old Nov 16, 2005 | 08:51 AM
TampaTurbo's Avatar
Originally Posted by QuickEvo
Chad, I completely understand what you are saying. However, I wont be injecting straight meth. As you said, I'm also curious to see the difference in temperatures before and after WI. Regardless of water/alky/meth injection you're going to shorten the life span of every sensor across the board when using those particular setups. It's par for the course.
My AIT is after the BOV. I am also running straight meth. I figure it was mostly important for cold start issues but I would be wondering as well if the sensor could take the methanol.
Old Nov 16, 2005 | 08:55 AM
Torre from Va.'s Avatar
someone should move this to how to thread...... seriously aem is still down and (justin) in tech sucks ***. Chad C.............kcevo is the man !!
Old Nov 16, 2005 | 09:07 AM
kcevo's Avatar
Thanks for the compliments, just trying to help out my fellow evo community. Thought the site was back up and I was hoping to do a review of the V1.19 and post it here, but it looks as if my injector drivers on my AEM box are shot and it needs to be sent back for warranty.
Old Nov 16, 2005 | 09:10 AM
Chad,that sucks............. you should post your know how in how to section...............your a big help. I rather call you than tech line...........I'm going to choke that justin dude !!
Old Nov 16, 2005 | 09:21 AM
kcevo's Avatar
Chad,that sucks............. you should post your know how in how to section...............your a big help. I rather call you than tech line...........I'm going choke that justin dude !!
Yeah, i talked to him yesterday about my ecu and he wasn't that much of a help, but I figured I had already exhausted all of my options besides the stock ecu and wanted to check with AEM for anything else just to be sure. I know I posted a how to on the AIT, MAP, and Boost solenoid back in November of 2003 when I first put the AEM in. They need to just put a sticky up at the top for all of these and leave them there. The 1313 pdf instruction file now tells you how to wire in the MAP sensor at least, but most don't take the time to read that or any of the pdf manuals that come with the software. There are quite a few things that I posted in regards to the AEM as well as others that have been asked multiple times that could have been stickied or found with some good searching, but I know how time consuming and frustrating the searching process can be.
Evo_Goodness
Sep 29, 2016 10:31 PM
Evo_Goodness
Aug 25, 2016 09:01 AM
EvilEvolution8
May 10, 2016 01:41 AM
murderedout
Mar 4, 2016 11:05 AM
Tym Switzer
Oct 26, 2003 07:39 AM
