how do i scale a bigger set of injectors with the AEM??
Originally Posted by rraulston
Getting a set of 780's. What needs to be changed in my cal file??? RRR
This will get you close as long as you have accurate flow data. You will probably have to do some tweaking to get it just right.
-Mike
Originally Posted by Inn-Tune
In the setup menu change your fuel injectors using the battery offset wizard. Then go to the main fuel table and right click somewhere on it and select change injectors. Put the old and new flow rates in.
-Mike
-Mike
yup thats a good place to start, make sure you put in the correct fuel pressures as well.
most of the time you will have modify after putting new injectors. as different injectors flow differently at certain duty cycles.
good luck
WTB[West]: Front Coilover or set
maxroach
Apr 13, 2017 09:01 PM
OneCrzyEvo21
May 24, 2016 10:34 AM
