AEM EMS Get tuning help for your AEM EMS system.
AEM EMS?? Is it possible to do boost logs?
Old Feb 17, 2006 | 08:41 PM
Blue Evo 8's Avatar
I have an AEM EMS on my 05 EVO and was wondering if its possible to do boost logs?
I.E. I'd like to see how much PSI I'm making every rpm from like 3000-7500RPM
this way i can see if I'm leaking boost, how much boost is tapering, and where boost peaks at??
Please let me know
Old Feb 18, 2006 | 01:15 AM
levo2nr's Avatar
i dont mind know about this 2
Old Feb 18, 2006 | 01:27 AM
Widebandphillip's Avatar
Sure, just get a laptop and connecto to the aem. Make sure the parameters read boost and rpm. Hit f6 for logging and hit it again to stop and name your file. Open the .stf file in aem log and there you go.
Old Feb 18, 2006 | 01:32 AM
levo2nr's Avatar
that is the thing i dont see boost inthe parameters
Old Feb 18, 2006 | 01:39 AM
levo2nr's Avatar
is it boost target
offf topic sorry but what is the ADRC0# numbers at the end for
i mean what does that read?
Old Feb 18, 2006 | 05:31 AM
Blue Evo 8's Avatar
bump for clearer responses
Old Feb 18, 2006 | 10:34 AM
ExViTermini's Avatar
just get the laptop up and connected, go for a drive
before you hit it push F6 on the laptop. Run your gear out or whatever then hit F6 again and save the file
Open it in AEMLog and it asks you what three parameters you want to graph, make sure one of them is Engine Load and your done.
Old Feb 19, 2006 | 08:34 PM
Mase's Avatar
Your boost pressure is scripted as "Engine Load" most of the time people use PSI units.
open your main parameters, it should be close to the top.
Old Feb 19, 2006 | 08:40 PM
platinumspecv's Avatar
do this... Turn on your TUNING params and hit F6 when you want to start the log...then F6 again when you want to stop logging. It will save the log. In AEM LOG you want to open up the file and you want to plot ENGINE LOAD and ENGINE SPEED. Those two will show your PSI vs RPM. Good luck
ch1215g
16
Feb 20, 2011 10:46 AM
gudmundur
Jul 16, 2007 02:29 PM
Blue Evo 8
33
Jan 17, 2006 05:07 AM
EVO8LTW
Mar 2, 2005 02:26 PM
chinalfr
AEM EMS
Jun 5, 2004 06:48 AM
