AEM EMS Get tuning help for your AEM EMS system.
intercooler sprayer with ems.
Old Jul 24, 2006 | 05:39 PM
BANKS 2's Avatar
TT tune my car.. but i noticed the intercooler sprayer doesnt work anymore since the aem install... not that i really care bc it doesnt do anything (i think)
but just a question.. where would i find this switch in the aem program to turn it on?
thanks fellas
Bill
Old Jul 24, 2006 | 06:34 PM
Spaceball 1's Avatar
its idle 7/8 on the outputs the switch wont work anymore but you can set when it comes on due to the parameters
Old Jul 24, 2006 | 07:38 PM
jbrown's Avatar
Yeah, the switch is toast, but you can totally set when it comes on, based on AIT, TPS, EGT, etc. that way it only comes on when you really need it to. Just keep an eye on it to make sure it's always full or you obviously won't get any benefit out of it.
Old Jul 24, 2006 | 11:36 PM
Fourdoor's Avatar
When I had the 03 I set mine to come on at 15 psi of boost. Worked just fine I put in a different switch in place of the intercooler sprayer switch and used it for other things that could be turned on or off with the AEM EMS.
Keith
Old Jul 25, 2006 | 06:26 PM
jbrown's Avatar
I definitely recommend you take AIT into consideration as well, no reason to use the sprayer if your AIT is already so low that spraying the IC won't help.
Old Jul 26, 2006 | 06:07 AM
forbidden color's Avatar
How do you make the AIT one of the parameter on the idle 7/8 output?
and do you check the function button for this?
Boostlife4g63
Jul 10, 2014 06:32 AM
jtcarstens
Mar 25, 2014 06:11 PM
jtcarstens
Feb 7, 2014 10:43 AM
sternevo8
Mar 8, 2013 10:42 AM
neuspeed
May 24, 2011 07:29 PM
