AEM EMS Get tuning help for your AEM EMS system.
Question
Old Sep 16, 2006 | 08:27 PM
EVO2003VIII's Avatar
Question
Hi to all
I'm planing to put an aem computer 1313 to an evo8 2003. Do I need to change the map sensor of the engine or it's just put it on.
Thanks.
Old Sep 16, 2006 | 08:38 PM
Kerr's Avatar
Fomer Vendor
Answer:
You have to add a map sensor, and an IAT sensor. And do you have an EMS yet? Im selling mine, https://www.evolutionm.net/forums/sh...d.php?t=223769
Old Sep 17, 2006 | 08:56 AM
I'm running with the stock computer but my adds are:
HKS 272,264 cams
HKS Cam gears
HKS blow off
3" exhaust
eboost controller
arp head studs
reflash
where can i find those parts that i need?
I already have an aem 1313.
Old Sep 17, 2006 | 09:17 AM
althemean's Avatar
Buschur has them. I converted over using only the aem sensors. I also didnt need the GM boost solenoid. The stock one worked fine for me. Ditch that eboost controller...it not needed. Buschur will push the 5 bar map sensor but if you plan on staying with the stock turbo I recommend the 3.5 bar, it will have better resolution for daily driving.
I would also recommend upgrading your fuel pump and injectors at the same time. With just a TBE and k&N cone filter my car reached 93%IDC and it eventually led to a fuel pump problem which blew my motor. These parts are necessary when switching to the AEM IMO.
Old Sep 17, 2006 | 10:02 AM
sorry for that part, I also have a fuel pump walbro 255. So many things in my head and sometimes I forgot things. The car made at the dyno 340 hp. Never take it to the tracks.
Also what I'm planing to do is first put on the aem and later on I already have some mayor modifications to the engine....
A:
gt30
1000cc inyectors
exhaust manifold.
Right now it's running with the turbo of the 2005 models at 20 psi of boost.
I already tunned and evo with and aem and it work perfect. That car in particulary have...
gt 35
272 cams
springs, retainers
3" exhaust
exhaust manifold
external waste gate
1000cc inyectors
intake manifold
2 fuel pumps
braider 8 fuel lines from tank to fuel rail
wiseco pistons
eagle rods
arp head studs
it's in break in right now but i left it at 21 psi of boost. As soon as it's done for some miles on it will go to the dyno to boost it up a little bit of at least what the owner wants.
eddy
Old Sep 17, 2006 | 10:13 PM
jbrown's Avatar
you don't need a map sensor unless you want to ditch your MAF. You can make more power without the MAF, but the car will run fine with the AEM and all of the stock sensors.
Old Sep 18, 2006 | 04:56 AM
EVO8_PR's Avatar
A:
gt30
1000cc inyectors
exhaust manifold.
gt 35
272 cams
springs, retainers
3" exhaust
exhaust manifold
external waste gate
1000cc inyectors
intake manifold
2 fuel pumps
wiseco pistons
eagle rods
arp head studs
eddy
When I was bone stock i was left reading you license plate from 3rd gear on,
things could be quite different now...
Old Sep 19, 2006 | 12:25 PM
Lightbulb
At that time I was almost stock but at least you were behind me !!
I thought that with some modification to my car the other day I was going to gain more horsepower but ....lets see what I can do next to change does numbers ..
thanks.....
edy
Old Sep 19, 2006 | 03:40 PM
EVO8_PR's Avatar
I honestly think your car has too much timing.
Carrier
Apr 8, 2011 01:46 PM
Smogrunner
Jan 15, 2008 07:54 PM
riceball777
Dec 2, 2007 05:40 PM
4ce fed
Apr 4, 2005 07:30 PM
