AEM EMS Get tuning help for your AEM EMS system.
AEM Tru Boost Tips
Old Oct 2, 2006 | 07:58 PM
Boston'sEvO-->8's Avatar
AEM Tru Boost Tips
Hey guys...I have the new AEM tru boost gauge installed in my car. Everything is installed correctly but I need help raising the boost on the gauge. Is there any write ups that are easy and straight forward. I cant get the boost above 12-13psi. My goal is to get it up to 22psi. I had a MBC before never had issues. Does anyone else have this unit and if so can you give me some tips on what to program and how. BTW the pics of all the tru boost show the leds lighting up all the way as you build boost. I have only seen the single LED go up and down as you build boost.
THANKS!!!!
Old Oct 3, 2006 | 06:59 AM
jbrown's Avatar
I don't have any experience with this but if I had to guess, I'd say it's one of two things:
1. You have the solenoid hooked up backwards.
2. Some EBCs have a setting for poppet or flapper style wastegates, the stock one is a flapper, you may have selected the wrong one.
Edit: I meant to say "I don't have any experience with this particular EBC"
Old Oct 3, 2006 | 07:13 AM
OooOOO I might have to bring it by the Shop that installed it to check it out...Thanks for the advice. If anyone has experience with this EBC do they have a setting lay out so maybe I can try that and if that works then its not the hook up. The shop I took it too is pretty good so I would guess they did it right but like you said Jbrown you never know...
Old Feb 24, 2007 | 09:07 PM
TurboIX's Avatar
I think it goes by Duty Cycle...
ChicagoEvo9
27
Jul 27, 2013 07:48 PM
AlTheChino
Evo X Dyno Results
30
Apr 4, 2011 04:07 PM
raasfaas
Oct 25, 2008 07:26 AM
MirzaJinnah
May 23, 2007 01:44 PM
Redline-Z
Dec 13, 2006 06:53 PM
