AEM EMS for the IX
I have to agree with that along with my tuner. We already adjusted the idle and a/c compensation so now when the a/c turns on and off, the transition is much smoother.
Originally Posted by slo4g63
Well, just by stroke of luck and timing..... EMS came in yesterday at a local shop here in Colorado.... Hope to get it installed by this Saturday, not sure of exactly when we will be dyno'ing, the shop and I have very conflicting schedules at the moment but I will try and keep everyone updated!!!!!
Originally Posted by diablo2184
any bugs or anything found with this unit? whats the progress?
Idle - still working on it.... Rarely stalls now, getting much better. Stock vs EMS on power curve and mivec controls are near same. Awaiting for another day to dyno/tune again.
EMS still maintains power after key removed, runs battery dead after 16 hours of sitting but good for an overnighter. Blew one 10amp main relay fuse, no biggie.
Still have plans for the car as far as power adders, still have conflicting schedules with the shop and my car. Sorry for the slow progress but these things take a bit of time.
Originally Posted by EvoVIII_MR2005
So have you discovered a way to not make the EMS run your battery dead?
Will keep updating.....
Originally Posted by DenverEvoIX
It is a different plug and no you could not use a 30-1313 to control the new MIVEC valvetrain. Different hardware setup...
A/C is kept with the AEM EMS, but I think you can set an A/C shut off with either Throttle Position of RPM, i forget.
And for the EMS still maintaining power, is the Main Relays or something like that hooked up and wired properly? By reading the wiring diagrams, i think you should be able to have an easy fix for that.....
read the whole thread first before you post, all your questions have been answered already
