AEM EMS Get tuning help for your AEM EMS system.
What does your A/F trace after shift look like?
Old Dec 14, 2006 | 11:28 PM
Aby@MIL.SPEC's Avatar
I am curiuous to know what other people are seeing for their a/f trace after shifts.
can you post a log of rpm, a/f & throttle please of you mowing through a 1/2/3 upshifts?
I have a lean spike that i cant get rid of, which appears in my mind, as being excessive.
TIA
i will post a log later, as i dont have any data on this machine.
Old Dec 15, 2006 | 07:37 PM
brobards's Avatar
Most of the time when you shift the log of A/F will spike lean. THis is because of the decel fuel shutting off the fuel injectors when you let off the throttle. If however you are at WOT and the A/F are spiking lean I would be worried.
Old Dec 18, 2006 | 04:48 PM
David Buschur's Avatar
Look at your accel fuel maps/settings. It is normal to have a short lean spot right after the shift, it is fairly impossible to get rid of it all completely. You will probably found out if you do it will be too rich. If you want to send me a log I would atleast look at it and see if it looks normal.
Old Dec 25, 2006 | 08:04 AM
Silk's Avatar
So if you can manipulate your map to spike rich upon upshifts can you expect a nice fireball/ bang ?
Old Dec 25, 2006 | 07:32 PM
brobards's Avatar
You can just set your Fuel off above RPM high under the decel fuel options if you want to see a fireball when you shift.
Old Dec 25, 2006 | 07:38 PM
Silk's Avatar
Not really a serious question as a fireball just seems like a premature turbo rebuild waiting to happen but, what do you mean by setting my fuel off? Dont you require fuel for the bang and shutting it off just seems like it would create an even leaner condition than the one mentioned above.
Old Dec 26, 2006 | 06:50 PM
brobards's Avatar
On decel fuel your injectors will shut off when your throttle is lifted. By setting the fuel off above RPM high (7000 for example). You are telling the EMS to shut off the injectors once you lift the throttle for any RPM above 7000. If your engine RPM is below 7000 your injectors will be firing as normal which would cause the fireball in the exhaust.
Old Dec 26, 2006 | 07:22 PM
Dave2's Avatar
Hey David, are you familiar with Power FC accel fuel map setting? Sometime when i was crusing.. then WOT, my knock reading is high
Here is the info i got from my Power FC setting, Can you take a look at it?
thanks
RPM Amount Decay
5000 2.800 0.800
4000 3.000 1.200
3000 3.500 1.200
2000 3.800 1.000
1000 4.000 0.500
tsitalon1
Feb 22, 2014 07:23 PM
cam2
Oct 21, 2003 07:36 AM
