A/F and O2 settings on Apexi TT
Old Oct 19, 2003 | 01:33 PM
cam2's Avatar
For those of you that have the Apexi Turbo timer, what settings do you use for the A/F and the O2? I had the Turbo Timer installed the other day and the A/F and O2 were set at the highest settings, and I noticed the idle times were very high.
Old Oct 19, 2003 | 01:52 PM
3K's Avatar
3K
Do you have the user/install guide? If you do then follow the instructions for calibrating the A/F, and O2 settings. It's not hard at all to set-up. As for the idling times set it to auto mode and set the lowest setting for 8 sec. and the longest for 10 minutes. and set the manuel mode to 30 sec. low setting and 3 min for high setting. hope this helps.
Old Oct 21, 2003 | 07:36 AM
sevensign's Avatar
Yep...setting comes in d manual, easy to set, now now where did i put it....its here sumwer
malac0da13
Dec 5, 2010 05:53 AM
cyrax5709
Lancer Engine Management / Tuning Forums
22
Jan 15, 2007 10:57 AM
WishIhadaEvo
Jul 3, 2005 10:25 AM
essjEVO
11
Mar 19, 2005 12:12 PM
shinji96
Oct 27, 2004 10:56 PM
