AEM Serial guages.
AEM Serial guages.
Well, I finally got around to installing my AEM serial gauge, and I have to say I love it! Being able to programe the LED display that goes around the digital display is a great thing. For example, on my wide band O2 reading I have it set up to do a green LED sweep from 14:1 to 16:1 (normal cruise and idle range) and on the same set of LED's it sweeps from 10:1 up to 11:1 in yellow from 11:1 to 12:1 in green, 12.1:1 to 12.5:1 in yellow and from 12.6:1 up to 13.9:1 in red... this of course is my WOT range with the red being BAD of course
I did multiple LED sweep readouts for coolant temp and boost pressure and vehicle speed as well (up to 65 mph is greed LED's, from 66 to 75 has yellow LED's and 76 and up in red)
I love this thing, and if it was just a bit cheaper I would have 3 or 4 more of them.
Keith
Keith
its like $299 retail right?
I'm planning on getting 1 aem serial gauge, a stewart warner boost gauge,
the engine oil temp, oil pressure and then water temp gauges.....
Does the serial gauge have a wideband built in?
You can either have the laptop plugged in to the EMS or the gauge plugged into the EMS.... I don't know if you can use the additional pigtail to have both pluged in at once, but that is NOT addressed in the instructions, so I would not try it without clarification from AEM.
Keith
Keith
Keith
Keith
Keith
Mellon Racing
Evo 'For Sale' Electronics / Lighting / Audio
381
May 24, 2013 05:54 PM
extremepsi
Nov 14, 2008 09:58 AM
